  • 11 Replies
  • 6312 Views
WinnieWinnie
Why do I only have 6 days of rolling storage when I used to have 7?
11 REPLIES 11
ksss11
Virtuoso
Virtuoso
We went down to 6 days too.
Can anyone answer why?
JessicaP
Hey WinnieWinnie and ksss11,
Do you have a screenshot that shows your storage went down from seven days to six?
ksss11
Virtuoso
Virtuoso
I posted that and then in the same session that I was on, I went to library and it is back to 7 days after a week at 6 days. So HMMMM.....
ksss11
Virtuoso
Virtuoso
I have 6 days again. Don't know how to do screenshot.
WinnieWinnie
Only 6 days have green dots showing recordings. I hope you can view the screenshot
JessicaP
Have you tried rebooting your Base Station to see if that helps? Are you only seeing six days worth of recording on the web client on your computer too?
migman_2001
Luminary
Luminary
I have noticed the same issue.  5 days with green dot plus the current day, 6 total.
Rebooted the base with no effect.
Issue is on iOS devices.  All apps and firmware up to date.
WinnieWinnie
THis is really strange... I didn’t get a chance to try any of your suggestions yet but I have 7 days again. 🤷🏻‍♀️ Keeping an eye to see if it’ll revert back to 6.
JessicaP
Hi migman_2001,
Are you seeing this problem through the web client on your computer? Try testing by using the default "Armed" mode for each day (not for the full day) to see if you have 7 days worth of recording.
WinnieWinnie
I am back down to 6 days of cloud storage. Just this morning, I had 7. I have the same problem when logging in thru the web
JessicaP
If you're still having problems with only showing 6 days of recording, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
