We have the camera in the front of the house, we have all the modes set, we are not on a schedule, we can see the activity live, we increase the sensitivity but the camera will not activate and record the motion.
Can you open tickets for all of us?
Okay, I've tried both schedule and always armed. It's also daylight before and after the cameras stop sending, so I am not sure if that is a factor.
I gather from responses that I should check the base unit lights at night and ensure my sensitivity is turned up, although daylight sensitivity is fine. I should also walk past the cameras at night in test mode to see whether or not the red light comes on. I'll take a few screenshots tonight.
This week my three Arlo Pro 2 cameras suddenly stopped recording video at night. Between 8:00pm and 7:00am they simply don't record. I have the 2.7.10 Software Version which appears to be the most recent. On June 12 they did record videos at night (I can see them in the library of the app), but after that they don't record anything for those 11 hours of night and evening. I know they are not recording becuase I have walked infront of them in those hours and there is no record o me doing so. They record fine durring the day.
I'm about to go out of town and am increadibly unimpressed with the shear unavailibility of support. This is the only place I could find to even begin to talk to someone. I am concerned that there will be no video if anyone tries to break in while I'm gone. These cameras were not cheap and I expected them to last longer than 6 months. I have seen that others have had this same issue and that Arlo stubbornly refuses to do anything about it. This is increadibly concerning to see from a brand which is supposed to be high quality.
Have you rebooted the base? What are the LEDs showing?
When you walk past the cameras at night do the night vision LEDs turn on.
What mode is the running at night.
I rebooted the base and it was showing three green lights. I won't know if it worked until later tonight.
I have had the system for about 6 months. That whole time it worked fine until a few days ago. I do not know how to check which mode it is running at night. The red leds are on at night when I walk infront of it.
If you use schedules then check the mode for that time is correctly switching.
If you have USB backup, check if your getting recordings at night, could be a cloud based issue.
The current mode is armed. I have not tried any other mode. After restarting the base station it still does not record after 8:00pm until 7:00am. I am now out of town so there is no way to test it with a usb backup until I return.
That is correct, it just says armed with no other icons
Hope this helps.
https://community.arlo.com/t5/Arlo-Pro/Arlo-Pro-Is-Not-Recording-At-Night/td-p/1665689
I have already attmepted to power cycle the base station and it did nothing to fix the issue.
Unfortunately, that is exactly what I was worried about. I do have a contact higher up in netgear and I'm thinking I will need to contact them about this. It's very sad to see that what is supposed to be a high end product failing so easily and often.
Hi @dtshaw82
This may be a problem with the latest version 2.7.12(99) released July 10 2019 found in Settings-System-About. With this version, my cameras started recording video approximately 5 seconds after motion was detected which misses events. This is different from what the system had done previously. Everything worked fine until this version update. I did not change anything in my camera or system setup. Setup and camera recordings had been working fine for 6 months prior to this update.
