@Davey242 wrote:
I just tried the motion automation and it did work. There is a delay before homekit sees the motion and triggers the notification and automation.
Arlo app notification came a few second before homekit.
FYI all I did was update the arlo app, add the base/cameras when prompted within the app. The only setup issue I have is if I do to any device info in the arlo app, it will add a new temp home which I cannot delete
I had three homes set up in Home Kit and adding the Arlo did not add a Temp home for me. Thankfully.
However, it did only add the base stations for the home in which I was located at the time. I am now at a different home with a VMB3000 base station and an Arlo Q Plus. It appears that neither of those has a Home Kit setting. I did notice that the one base station that was successfully setup in my other home this AM when I started the app. I could not set up the second base station during that initial process. However, I later noticed the HomeKit setting in the Arlo app and I was able to add the second base station using the Arlo app in settings. I also noticed the HomeKit settings don’t recognize the original Arlo cameras as HomeKit eligibile devices. Only Pro and Pro 2 cameras qualify.
It is interesting that motion sensors and cameras are different devices in HomeKit
FYI, someone just told me that they were also seeing the "No Response" for one of their cameras and he removed the battery for a few seconds and then put it back in and now is working just fine and he no longer gets the warning.
I'll try that when I get home.
"It is interesting that motion sensors and cameras are different devices in HomeKit "
Yeah, I was confused by this when I first started using Homekit. I have the Hue motion sensor, and it displays it as 3 separate devices: motion sensor, temperature sensor, and light sensor.
Im having the same issue, I get the "No Response" warning. When you get back home, try removing the batteries from your cameras and then see if that restart helps your cameras work better in the home app.
Since it’s not certified, Apple won’t allow it’s data to be transferred over its network/Datacenter to for remote management.
So I believe until it is certified for HomeKit we will just have to use it when we are on the local network.
Hmmm, Im not sure. Other users are not having issues with their cameras away from home. It seems to be a random issue.
Good point, I totally forgot about the Homekit hub, which in my case its my Apple TV. I will start with the Apple TV and if that doesn't help, will restart all the cameras.
For those having an issue getting this set up, in addition to restarting your HomeKit Hub, also consider restarting your Arlo Base Station.
After completing a reboot, try again to see if you still experience the same behavior.
@JamesC You should pass this info to your chat tech support. I contacted them a few hours ago and the Arlo tech support person had no idea on what to do and all he kept telling me was to contact Apple and he kept blaming Apple for everything. He was getting annoying.
I actually learned a lot from this community posts
You are the first person I heard of that didn’t have remote viewing issues in the Apple Home app
No good, a reboot didn’t help me.
You and everyone else that have no issues with remote viewing are fortunate.
What model Base Station do you have?
@DeeZuL did you rebooted your homekit hub, basestation, and cameras?
VMB4000r3
Someone actually has live streaming video on an Apple Watch on WatchOS 6 beta? I can't get that to work on WatchOS 5 or earlier. I have NEVER been able to get that to work on the Arlo Baby either. (I take that back. It will work if I turn off wifi and bluetooth on my iPhone.)
Maybe there is hope. Maybe WatchOS 6 holds the key! Plus now they will have a lot more customers trying to view on their watches.
WOW! Good things come to those who wait!
I can see the motion sensor trigger in Homekit but the automation is not triggering the light.
Will try a power cycle on all hubs and see what happens.
@JamesC still not working, tried doing a reboot on everything, still getting the issue where it says the hub is not "certified"
One thing I can say is reboot everything.
Once I restarted my iPhone, I was able to delete all the temp homes that the arlo app set up. I had about 15 in there. When adding the arlo on one device and it not showing up on another device, rebooting the device it would work on resolved the issue. Rebooting the base station also helped with some things
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
