Failed to detect my base station in Homekit
  • 2 Replies
  • 2987 Views
drtklam
I am using Arlo Pro 2 and it used to be fine to connect to my Homekit. However, after I switched to use the Netgear Orbi RBK852 Mesh system, I failed to set up my basestation in Homekit as it failed to detect any device. All the firmware are the latest one. Please kindly suggest any solution.
ShayneS
Hi @drtklam
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
drtklam
Thanks. Problem solved after reset of base station
