aj22
Can I get a token reset as well?
Firmware: 1.17.1.2_3987_0e6c162
Hardware:VMB4000r3
74 REPLIES 74
Millie821,
I've sent another token. Do you still experience the same behavior?
Lasse_
Hi,
It worked for 1 of 3 basestations.
VMB4540r2
Serialnumber A0E2017LA08D9 - able to add and works with Homekit
VMB5000r4
Serialnumber 5GP60C7VA0747 - in HomeKit when adding it says "Not certified device", and then "can not add accessories, the setting code is incorrect" (tried using the qr code and writing the numeric code manually that is on the sticker)
VMB4540r2
Serialnumber A0E2067XA0A20 - in HomeKit when adding it says "Not certified device", and then "can not add accessories, the setting code is incorrect"
Lasse_,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Millie821
Yes unfortunately I’m still not able to see HomeKit in my app.
Talktotone
Could you please reset the Apple Homekit Token? For some weird reason they stopped working.
Talktotone,
Your base station must be online to receive a token refresh. Check the base station status and make sure it is online.
Talktotone
Hello thanks for getting back. I can confirm base station is online and connected to the net. Serial number 4RE3857AA11E9
Talktotone,
Talktotone
Thank you - all set up now
barlo
Can I get a token reset please?
sarge_ind
Hello,
Can I get my token reset as well please?
Thanks!
barlo, sarge_ind
Urbanski
Hi, I removed my Arlo base from HomeKit but would like to re-add it. Could you send a token reset request?
Urbanski,
Lasse_
Hi JamesC,
All 3 base stations works fine now with HomeKit.
Thanks for your help, appreciated.
Best regards,
Lasse
Paulmarkiewicz
Hello
Can I have a token reset as well please? I’m stuck on ‘Discovering your device. Please wait.’ Thanks
ShayneS
@Paulmarkiewicz
Thank you
aj22
Can I get it reset again please? Homekit stopped recognizing Arlo and I removed it from Homekit to try to add it again from Arlo but now it keeps spinning!
aj22,
aj22
Thanks James! I tried power cycling but it still doesn't work. Keeps spinning!?
Bender2996
Hi James,
Would you please send a token reset to my base station as well?
Pro Base Station Three-LED VMB4000
Bender2996,
aj22
Hi James,
Can you please look into this? It had worked before but this time around when you reset the token, it didn't fix the issue?
aj22,
I've sent a second token reset to your base station. Please try again and let me know the results.
aj22
Thank you! It worked this time. Appreciate your help.
