Can I get a token reset as well?
Firmware: 1.17.1.2_3987_0e6c162
Hardware:VMB4000r3
Thank you
I've tried the steps of recycled power on the Base station as documented already. I also have the latest version of the app.
Thank you
I seem to have the same problem but was originally told to reset my base station and then re-sync all the cameras. Before climbing ladders and spending the day re-syncing 5 cameras,
could you try a token reset and see if that clears up my HomeKit problem>?
Thank you in advance.
Thank you
Can i get my token reset as well please
dropped
Thank you
Thank you - this fix worked.
Please make sure the support team (who answers the chat) know about this fix. They told me the only way to accomplish getting the device reconnected on HomeKit is to reset the base and re-sync all devices.
Hi @Stroodle
It sure is, I have reset your HomeKit token, please reboot your base station and try again. Also, please make sure you have the latest version of the Arlo mobile app v3.6 installed.
Thanks for the reset and info. I did restart the base station and confirmed all devices have the latest firmware as well as the app but during setup for HomeKit, no device is found now? Previously I would see it very quickly but in the next few steps it would fail. Now I can’t get by the first screen in the setup. Any ideas? I’ve tried different access points on the network, even though I can view the cameras in the Arlo app on any of them, with no change.
Disregard the last post. It’s now working and I was able to set it up. Thanks.
Base station is wired to router with extremely fast internet. Gigabit.
@DaDon I have reset your token, please reboot your base and try again.
Hi can I request a token reset. Apparently that’s what I need to do to fix my HomeKit connection problem
1.17.1.2_3987 0e6c162
bluebrightfire,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
hi i have 2 base stations thati want to have a homekit reset please
DvxAznxvb,
Hello. I’m having troubles connecting Arlo to HomeKit. Worked once before. Have 3 basestations. Token reset seems to be the key to this issue. Please send me that if thats what i need to fix my connection problem. Thanks.
- VMB4540r2 1.18.0.3_1136_d554faf
- VMB5000r4 1.18.0.3_1197_d554faf
Lasse_,
Can you reset my Homekit tokens please?
Can I get a token reset as well to my base station?
petermfox, Millie821
The token reset does not appear to have worked. I’ve powered off the base station twice. The HomeKit feature still does not show up in my Arlo app. I’ve tried uninstalling my Arlo app as well. Are there any other solutions? Thanks for you assistance.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
