Can I get a token reset as well?
Firmware: 1.17.1.2_3987_0e6c162
Hardware:VMB4000r3
Millie821,
I've sent another token. Do you still experience the same behavior?
Hi,
It worked for 1 of 3 basestations.
Lasse_,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Talktotone,
Your base station must be online to receive a token refresh. Check the base station status and make sure it is online.
Talktotone,
Thank you - all set up now
Can I get a token reset please?
Hello,
Can I get my token reset as well please?
Thanks!
barlo, sarge_ind
Hi, I removed my Arlo base from HomeKit but would like to re-add it. Could you send a token reset request?
Urbanski,
Hi JamesC,
All 3 base stations works fine now with HomeKit.
Thanks for your help, appreciated.
Best regards,
Lasse
Hello
Can I have a token reset as well please? I’m stuck on ‘Discovering your device. Please wait.’ Thanks
@Paulmarkiewicz
Thank you
Can I get it reset again please? Homekit stopped recognizing Arlo and I removed it from Homekit to try to add it again from Arlo but now it keeps spinning!
aj22,
Thanks James! I tried power cycling but it still doesn't work. Keeps spinning!?
Hi James,
Would you please send a token reset to my base station as well?
Bender2996,
Hi James,
Can you please look into this? It had worked before but this time around when you reset the token, it didn't fix the issue?
aj22,
I've sent a second token reset to your base station. Please try again and let me know the results.
Thank you! It worked this time. Appreciate your help.
AppleTV
31 -
Samsung SmartThings
81 -
Security System
