HI @Retired_Member
I have reset your tokens, please reboot your Base Station and try again.
I need a homekit token reset as well, please.
Hello. Have the same problem with my Arlo Pro base Station (VMB4000r3). Can you reset it? thanks
Hello,
Can I please get a token reset on my Base Station VMB4000?
Thank you.
Hi, can you please reset my token ?
Any plan to add that option in the app in the future ?
It didnt solve the issue, still stuck on Discovering your device...
After a few minutes, it worked. Thanks !
Hello,
I have the same issue, can you please help me with this issue?
What info do you need from my side?
Thank you!
Thank you
Hi @Rkalpee
Thank you
AppleTV
33 -
Samsung SmartThings
88 -
Security System
