Hi, I just purchased and installed a new base station (with another account) in Spain.
Same issue than in France/Paris, I am unable to add it to my Home in HomeKit.
Could you please reset the token of the VM5000 linked to this email address/account please ?
Thanks a lot
I have reset your tokens, please reboot your Base Station and try again.
SORRY!
BUT... CAN YOU HELP ME TOO?
I CAN'T CONNECT MY ARLO CAMERAS TO APLPE HOMEKIT
Can you also send me a reset token? Haven’t been able to setup HomeKit with my Arlo pro 2 since the feature came out!
It seems that I need the token reset as well. Please include me in the next batch.
Thank you,
msjeremyc
I have reset your tokens, please reboot your Base Station and try again. If you are having an issue still, please make sure you have the latest version of the Arlo mobile app. You can also try removing and reinstalling the app.
You can try removing & reinstalling the app. These are the compatible base station/Smart Hubs How do I connect my Arlo camera to Apple HomeKit?
Reinstalling the app and resetting the base station do not work.
How can HomeKit disappear from the app? Was it removed in a recent update?
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Can someone please reset my homekit token for Base station 5GN59A7GA0065
Hi, could you please send me a Homekit reset token as well?
Thank you!
Can you please reset my token as well.
My HomePod Mini's stopped chiming ... can you please send a reset token?
Thanks,
Els
AppleTV
33 -
Samsung SmartThings
90 -
Security System
