Can you reset my HomeKit token please?
I'm unable to setup HomeKit after it stopped working on my iOS and Mac devices.
When I go to setup in the Arlo app, it spins forever on the "Discovering your device" page. I've rebooted the Arlo base station and also rebooted my iPhone where I'm trying to set it up.
Apparently there's some sort of HomeKit token that you can reset for me?
Thanks,
Scott
That fixed it - thanks!!!
Scott
Hi @ShayneS,
Could you please reset my HomeKit token? I am having the same issue where the Arlo app doesn't go past the searching for devices screen while attempting to setup HomeKit.
Thanks!
Good evening,
Just like everyone else with Arlo Pro 2, I am trying to setup HomeKit and need a token reset.
Many thanks,
Mike
Mine were working, but now they no longer work in Homekit, though they were fixed by a toke reset many weeks ago. This is a very, very bad way to try to remedy this. I'm seriously going to get rid of all my Arlo equipment if it's not dependable and the token reset has to happen every few weeks.
Hi,
Here’s another one that need help with token reset… please…
Hi,
Sorry to hijack this thread, could you send me as well a token reset request.
Rgds, Ajay
Hi,
Can I also get a token reset. Looks like I have the same issue.
Thank you.
I have reset your tokens, please reboot your Base Station/Smart Hub and try again.
Could you please send a reset token to my BaseStation (VMB4000) as well? I'm having this same issue.
Discovering your device. Please wait.
I'm jumping on with requesting a Token Reset for my device so I can get it setup with HomeKit as I'm also sitting on the waiting for the device to be discovered.
@Retired_Member @dotfortun3 @SoJurn
I need a reset too please. Stuck on discovering devices.
AppleTV
31 -
Samsung SmartThings
82 -
Security System
