I even brought an Apple TV 4K next to it and plugged it in as well for power so it was all within feet of each other.
Why?????
That did it. Thx!
I don’t mean to be a bother at all I am just frustrated with trying to follow instructions that simply don’t seem to work.
I have the same issue, I bought a refurbished base station to connect my cameras to HomeKit and it says device is out of compliance.
jason
Firmware is up to date, and I’ve power cycled the hub a couple times now.
I cannot believe this integration with HomeKit is still a problem with Arlo. I noticed around a month ago my cameras were no longer working in HomeKit after working fine for around a year. I finally deleted them from HomeKit and started the integration using the Arlo app when I got to the same issue that everyone else has encountered indicating “searching for device” and getting no further. Since I am running the latest firmware and the Arlo 3.5.8 and still having a similar problem with people going back 3 years without a reasonable software fix from Arlo I can only assume the Arlo team cannot fix the issue as it must be a bug deep within the code. Please provide me a token reset or whatever work around the team has come up with before I remove the cameras entirely and go with another competitor. Thank you
Done and works
thank you
@ShayneS
How can I request a reset token for base station as well?
Can you please reset my Homekit Token on my Arlo Pro2 Hub. It used to work without issues but not I can't get it to connect to the same access point and Home. I reset the home in homekit, rebooted but the problem persists.
AppleTV
29 -
Samsung SmartThings
78 -
Security System
