Same issue. If I can't use with homekit, i'll have to find another solution. Any resolution to this?
Hi @Tcalhoun
Can you please PM me with your Admin email you used to create your Arlo account & I will reset your Homekit token.
PM sent.
Thanks Shayne
Hi @paulbw
Hi I'm having the same issue with my VMB5000r6. Does my device need the token updated?
Hello,
Could I also please get a token reset? Thank you.
Resolved! Thanks!
I’m having the same issue. I know this thread is old but is it possible for me to get a token as well?
I have the same issue. Can you please help me?
I have a vmb4500.
Hi @DanneArlo ,
I have reset your token. Please reboot your Base Station and try again.
Thank you,
Mark V
L3 Tech
HI @ Romycno
Pouvez-vous s'il vous plaît me PM avec l'e-mail de votre compte administrateur que vous avez utilisé lors de la configuration de votre système?
Merci
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
