- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB5000 homekit fails with uncertified accesso...
Please reset my token.
Doesn't seem to do anything. Can you try again please?
Could i get a reset token please as had to remove apple homkit and want to add it back on
I need a token reset
Still not coming up. I don't have a HomeKit setup code on the base station and the HomeKit link in the Arlo app does not appear. Any ideas??
I have two VMB4540 smarthubs. For some reason, one of them stopped working with HomeKit recently. Could you please reset my HomeKit tokens?
Hi, that time again to hijack another post to request a token reset please so i can re add my arlo to homekit please?
thanks in advance
I need a reset again.
I assume this issue would be resolved. When I select Setup HomeKit, it starts spinning on Devices Found but never returns. I’ve bounced the Bridge a couple times to no avail.
‘’Please advise.
@Retired_Member
You can try removing and reinstalling the Arlo app.
Hello, can I get a token reset please? Thanks.
Hi @kcjchan
Thank you
I have removed the arlo app (uninstalled) and rebooted the bridged/hub and verified the firmware was up to date. I am still having the issue. I’m not sure if it matters but I have Ultra’s, Pro4’s and Pro’s.
Bridge/Hub Info:
MODEL VERSION: VMB5000r5A
FIRMWARE VERSION: 1.17.2_1157_0e6c162
PHONE INFO:
OS: Apple iOS
MODEL NUMBER: ML9C3LL/A
SOFTWARE VERSION: 15.3.1
@Retired_Member
Do you have another iOS device you can try from?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
