- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
I’ve set up my VMB4000 Base station with 1 Arlo Pro camera and 3 Arlo Essential cameras, and when I try and configure HomeKit on the base station, it gets stuck on the discovering step and won’t actually connect. Can I get some help?
783 REPLIES 783
I need a token reset to get HomeKit working as well. Thank you!
Travis
Travis
Hi everyone, I am having the same issue too.. unable to use my Arlo cameras with HomeKit. My Arlo app is up to date and it seems I need a token to reset my base station.
How to get this token ?
Thanks,
Thanks,
My homekit integration also stopped working, and I am unable to set it up again. Can I also get a token reset please? Also, why not allow the user to reset his/her own token via the app as suggested a few months ago on this very thread?
I have reset your HomeKit tokens, please reboot your base station/Smart hub and try again.
Hi, mine didn’t work initially after token reset but I worked out why. I have a double NAT setup. I unplugged the VMB4000 from the main router and plug it into the wifi router so both are in the same subnet and it worked after that! Not sure if you have a similar setup though. Hope you have success soon.
Could I get a token reset please. HomeKit integration stalls on the discovering page.
thanks
Hi looking for a token reset to help set up HomeKit for Arlo.
Thanks all up and running now!
Thanks token reset worked, all up and running in HomeKit now
Can I get a reset sent to my base as well?
Hi Shane, can you please reset my token as well?
Latest updates installed (app and hardware) but still not recognisable by HomeKit
Thanks a lot. Ali
Thanks a lot. Ali
My HomeKit has stopped working too, can I get a reset token.
Can you please send a token. I Cannon link Arlo to HomeKit.
Thank you in advance
Christian
Christian
i cannot get my cameras to be recognized by my wifi eventho they were before
@ShayneS
Can I also get a token reset?
AppleTV
29 -
Samsung SmartThings
78 -
Security System
