- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
Hello,
I have the same issue with the VMB4000 connecting to HomeKit. Could you please reset the token on my base station ?
Thanks,
Rob
Please can you sort mine out, trying everything to connect to home kit
Hello,
Same problem. Can you send token reset ? Thanks.
Thank!, problem is fixed.
I have the same problem. Can I please get a token reset?
One of your moderators sent a token reset months ago, but I wasn't able to get it to work. I have the VMB 4000 with updated firmware and *still* can't get it to integrate with HomeKit. Can you please help? I'm a long-time Arlo customer, but honestly quite frustrated that I and so many other loyal Arlo customers have been let down by this product. Arlo should be much more proactive about fixing this issue for its installed base, rather than making us proactively come here for a token reset.
Please help as soon as you can. Thank you!
Dave
Can I get mine reset so that I can record to HomeKit?
I have the same problem. I am unable to connect to Homekit
@PhilWglt I have reset your token. Please reboot the SmartHub and try adding to Homekit again.
sadly didn’t work. I’m always stuck at requesting HomeKit info
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Please reset my token also
I am having the issue as well. Are you able to rest my token as well? Thank you!
We are aware of an issue with resetting HomeKit tokens & getting stuck on a "Requesting Homekit info" screen. The Arlo development team is investigating this issue & we will provide an update as soon as possible.
AppleTV
Samsung SmartThings
76 -
Security System
