- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
I’m having the same issue trying to connect to HomeKit. Can you please send me a new token?
Hi @GelberHund
I have reset your SmartHub's homekit token. Please reboot the SmartHub and try again.
Hi JamesC, I am not able to connect to Homekit due to the "unauthorised" error described here by others. Please assist. Thank you.
Thanks, worked a charm 😀
I don't see the option to "Add to Homekit" when I look at my base station in the Arlo app.
If I start from the Homekit app, I see the basestation, but it asks for an 8-digit code, which I don't know and isn't on my base station.
Hello - I also need my HomeKit token reset. Thank you!
Can you send me the reset token?
I have the same problem with my VMB4000r3 base station. It won’t find the device (it had worked previously but now not).
Could you please send a new token to reset the condition?
Firmware:
I have the same problem connecting to HomeKit. Could you please send the token to my basestation.
Sincerly
Tommy
Thanks,
Terry
Hi! Having similar issues, I'm stuck at "Discovering your device. Please Wait".
Please help.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
