Thank you!
Can you PM me with your email address used when setting up your account. I will reset your token after I receive this info.
Hi @jrgriffi ,
I have reset your SmartHub's homekit token. Please reboot the SmartHub and try again.
Thank you,
Mark V
Same problem here. Could you reset my base station? Thanks.
I am having the same issue, could you reset mine also please. Thank you
Thanks in advance.
James,
My hub is refusing to finish the link for HomeKit as well. How do I get the token reset?
I have the r3 firmware and the first base station added fine, the second will not no matter what I do. It appears I need JamesC to send a new token request to the device so that it can be seen (from what I've read). James could you do this please? Please be sure to get my second unit and not the first. Serial ending in 0892. Thanks
Hi @ralfdav
Please let me know if you still experience this issue.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
