- English
- Arlo Forum Discussions
- Partner Integrations
- Getting stuck searching for compatible Homekit dev...
Motorsportuk, Fishbulb00
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
@JamesC, could you please send me a token reset as well? I too am having fits with adding my Arlo base station to HomeKit.
Thank you.
Dave
Hi James,
I am still having issues, Homekit is now working on both my VMB4000 and VMB5000 which is great, however my library on the VMB4000 has now disappeared, it has intermittently returned a couple of times today but is still blank. The only thing that has changed (other than me resetting my wifi router) is the token being sent to it for Homekit, please help?
Thanks, Andrew
@Arlo, please help me with this ASAP. This issue should have been addressed FOR ALL OF US without having to find the fix and ask for it on your support site. Do better.
DavesFaves,
Motorsportuk,
If you're still experiencing an issue after i've sent you the token reset, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I have a similar but different issue. I see the HomeKit option and can click it. However, the Arlo app then searches for my HomeKit compatible devices and just gets stuck. It never leaves this screen (screenshot attached). Never finds my base station or cameras, but also never gives an error message.
I am trying to set up HomeKit and on the "Discovering your device" step, the app just hangs there with "Please wait".
Have verified firmware, as well as power cycled all devices (bridge, router, iPhone). I also reinstalled the Arlo app. From what I gathered, it sounds like I need a new token sent to my base station, can someone assist? thank you.
Hi JamesC, will you please send the token reset for my device as well?
Is there anyway @JamesC or anyone from Arlo could push the update token to me? I have been having the same issue for months. Excited to learn that there might be some solution.
Thanks.
@JamesC, it didn't fix my Arlo. The instructions are confusing, by the way. Is my iPhone supposed to be near to the base station (I assume that this is what Arlo intends) or near camera? In several instances, the instructions refer to having "the Arlo Camera powered on and nearby."
brlogan, jwpowell44
DavesFaves,
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Since you have exhausted all troubleshooting options I can provide, I would suggest contacting customer support to investigate this further. I wouldn't want you to performa a factory reset if it is not needed. You will find several options for contacting support in the provided link. Arlo Tech Support
Works great. Thank you so much, @JamesC .
I have 3 VMB5000r5's that fail with the same "Uncertified Accessory" error. All seem to be on latest firmware.
Hello everyone,
I have reset your base station tokens. Can you please try and add your devices again & let me know how it goes.
Thank you
I have 3 VMB5000r5's and all three show the same "Uncertified Accessory" error.
Andyx7
Hi James, Great!!!
All 3 are working now. Thanks for your help.
Andy
can I have this token resent to my base station for the HomeKit. I added 4 more cameras
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
