- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 homekit fails with uncertified acces...
Bryshi, Payneful13
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
That worked, thanks!
FurryYak,
RevErnald,
JayhawkLaw, Jlehman
Having same homkit setup issues, can you help send updated token to mine too?
Sceeter,
Lorix,
Would you please send a new token to my VMB4000r3 base station? I’m unable to add my device to HomeKit.
Thanks!
JG222,
Bduncan,
Hi James,
I am not seeing the base station appear when trying to set up with Homekit. Will sending a token reset fix this issue? If so, please send one my way.
Thanks,
djcruz04,
Could I also get the token? I just purchased these this week at Costco and I am getting the same error. My product is the ultra 2
Can you send the token to my base station? I’m having the same issue
AppleTV
33 -
Samsung SmartThings
87 -
Security System
