- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Getting 20-30 second delay when using Google H...
Just bought an Arlo Baby model:ABC1000, one of the main reasons was to integrate with my Google assistant.
Confirgured fine with the Arlo app, have this 2s delay with is acceptable for a wireless steaming camera, was able to integrate with Apple HomeKit, just to play and see how would work, everything is fine, even better audio quality (no tons of background/wite noise) and less delay, about 1s, then the arlo app. Big win for Apple software.
Now when if comes to Google environment, integrated ok but when casting to Google Hub or Chromecast on the TV have a 22s delay with the streaming witch is totaly unreliable for the use of this camera with Google assistant.
My wifi network is fine, not overloaded, AC router, 5hgz with band, good signal (not a big house) and worked fine with Arlo app and Apple homekit, this exclude the possibility of bad wifi set up. Have no problem streaming Netflix, music of other contant in my google assistant environment. Firmware is updated by the lastest release from Arlo app.
A 22s delay in a camera that supposed to help you take care of a baby is not a oppition.
Any sugestions on how can I make it work? or if it does work at all?
The Arlo development team is currently investigating this issue where some users are seeing a delay on live stream using the Google Assistant. We will provide an update as soon as we have more information to share with the community. We appreciate your patience and understand and apologize for any inconvenience.
Thanks for the update. I don't mind a newish product going through growing pains, but I was starting to become concerned with the lack of response/updates in the other thread (e.g., the 10+ page thread with title "Not Responding" message from Google Assistant"), especially with it being recently closed "due to inactivity" after a flurry of posts earlier this week.
As long as the platform is still moving forward and has plans for improvement, I am fine waiting a bit.
Experiencing the exact same issue. They simply shouldn't advertize google assitant / home / nest functionality as it's useless with the Alro Baby camera. Not only incredibly bad latency, but incosistent as well. Only thing that would have this kind of latency is if it's not streaming locally, but going out to cloud infra first, transcoding and then pulling playbacks from there. Would explain the crap video quality as well.
Has anyone experienced this where while viewing (with the 20-30 second delay) on a Google Home Hub (or other non-Arlo device) that motion and audio detection events are not recorded anymore in the library? The recording works as expected while not viewing on another device.
the delay is not the only issue going on. The cameras will only work 50% of the time and have severe issues trying to even connect to the lenovo smart displays. I dont understand why it has taken this long for the development team to look into this issue. this has been a day one problem since the lenovo displays were launched last year. Smart displays aren't going away, more and more people are buying them now.
I even uninstalled the app and reinstalled,
absolutely nothing.
I'm much better off streaming with my apple tv.
Any update?
I've have the same issue ever since I've gotten the Arlo Baby. It rarely works on the Google home hub, and when it does it has a nasty delay...at this point I have use the app on my phone. Still waiting for a fix...that might never come.
It's not just the Baby model. I haven Arlo Q Plus and a Google Home Hub. It takes about 15 seconds for the stream to start after Google says OK, streaming etc. The resulting stream is delayed by about 18 seconds. That's terrible.
@Nmatheny wrote:
netgear ... Netgear
Arlo ... Arlo. Netgear divested Arlo quite a while ago - they are separate companies.
Having the same problem, huge delays when connected to Google Home. Completely unacceptable.
Any update so far on the issue?
Hey Arlo, come on folks. It's been what, 7 months and no updates?
I'm experiencing the exact same issue on a Google Nest Hub. Lag reduces to around 3 seconds on iOS and iPad OS and web.
These devices are also on the same network with a high-end router so my original assumption was that the 3-second lag experienced over-the-wire would be reduced or maybe even eliminated with any luck. Not amplified by an order of magnitude. Absolutely crazy. I can tell you one thing, this makes me no longer wish to upgrade my Arlo camera hardware like I originally planned next month.
What gives, Arlo?
We've recently released a backend update which should fix the issue with experiencing any delays when live streaming using Google Assistant
If you're still experiencing this issue, please let us know.
Hey vanlewark,
Thanks for the heads up about this. I've informed the development team about this and they're investigating this issue. We'll be sure to update the community when we have any new information.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
