Hi I have just got the new iPhone XS max and it is synchronised to my cameras but it will not play my library videos but will play live events can you help please
So I didn’t really notice this before the iOS update, but not to say it wasn’t happening. I changed out the batteries in all my cameras, made sure they were still lined up, etc. my normal maintenance routine. Today I got an alert of motion at my front door. When I went to review the videos all I got was a still image of a car pulling in. The slider shows it is playing the 10 second clip but the image does not change. Got home and tested it, and same thing it shows the initial image of me walking into view then it keeps playing but the image doesn’t change.
I’m having the exact same issue with my new iPhone that has iOS 12
I am having the exact same problem. I had a suspicion that it was the result of using the new iPhone XS max.
I have reset, rebooted, unplugged, etc. ad nauseum.
Arlo needs to address a firmware update to correct this issue. I am left with a bunch of stills when instead I should have motion videos.
The worst of all, my property is no longer protected as it was before this snafu.
Please help Arlo engineers.
I could have written this paragraph myself. I am experiencing exactly the same issue.
I have IOS 12, and a new Iphone Xs Max. Not sure if either is the issue, but my library of videos don't play properly. The progress bar will move, but the video is a static image of the first frame and never moves. I can view on the web fine, so must be the app.
This is the reply I received from Arlo support: This has been reported to the Engineers and they are working on a fix for it. Please see this link for updates : This thread in communities quoted......
Ok tons of Arlo owners have stated there is an issue with video play-back on the new iPhone Xs and Xs max. You end up with still videos and any attempt to download and play in another app gives you a white screen. What we want to see is a commitment from Arlo to say they are working on a fix, if not then my cameras are going back to the shop..... so Arlo let us know soon or fix it!
They work hard since 8!!! days 🧐
With arlo pro 2 cameras and the issue is the same on all the cameras. When playing a video back the screen is frozen for a few seconds then the video picks up.
The downloaded video shows a blank screen for a few seconds then will play. Also can’t send in a text the videos.
The engineering team is aware and is currently investigating and working toward a resolution for this issue. We apologize for any inconvenience this has caused, while we work toward a resolution, we recommend using a browser to view videos.
I will provide an update as soon as I have more information.
iOS 12.0 iPhone XS Max
-What cameras are experiencing the issue (do you own a mix of pro and pro 2 cameras, original wire free, Arlo Q, etc.) Do they all behave the same or is it specific cameras that have the issue?
Arlo wire free. Same behavior on all cameras.
-If you download the recording, does it behave the same way or does the issue only occur in the library? Does the recording playback successfully on a different device or client?
Videos work perfectly on my iPhone 7 Plus and MacBook from a browser. Don’t know how to download on my phone. Download button seems to do nothing. I shared it with myself via iMessage and when I try to play the link it still does not work on my iPhone XS Max from a browser.
Your not alone.. as new OS comes out there usu are some bugs with the older apps.
You should contact Arlo support and send them a html email and let them know, the more that contact them, the quicker it will be fixed
