iPhone XS Max On IOS 12 Is Not Playing Videos In Library
Kevinleese49
Hi I have just got the new iPhone XS max and it is synchronised to my cameras but it will not play my library videos but will play live events can you help please
602 REPLIES 602
SL23
Arlo library will not play video clips on iPhone Xs?
Mccauley444
I installedd the 12.5 beta and the problem is fixed
MacMad
Seems like Arlo are just going to wait until 12.1 rather than fix the issue for non-beta testers.
ctrack
Luminary
Luminary
Seems like that’s passing the “buck”....
ozmale1
I told you so, Arlo NEVER update their apps or firmware unless its to support a new product.  Look at all the treads and complaints etc, none are ever resolved by arlo.
JessicaP
Hey @NIkkiG168,
What iPhone are you using? Are you also experiencing this issue through the web version on your computer?
Zandian
How do you explain this then in the Arlo App version history?
ozmale1
If you read between the lines of the release notes(sometimes release notes are impossible to find) there is always a reference to support or future support. And off course with apple always changing the IOS small profile changes have to be made for the app to even work.  Just look at the thread list very few if any are ever resolved, always some forum member comes ut with a work round.
NIkkiG168
I am using an IPhone XS Max. I can view recordings on my computer just not through the app anymore. Have tried to reinstall app and still not able to playback.
richld01
I am having the same issue, but on my iPhone. It started when I got the new iPhone XS currently running on iOS 12.0.1 and using the Arlo app version 2.6.0 I have tried everything I can think of to fix it and am still not having any luck. Please help.
Britdiver66
I have just upgraded my phone from a iPhone 6 to an iPhone XS. Since then the video will not play back in the Arlo app on my phone. It was working on the iPhone 6 with iOS 12 and is still working on my older iPad that is also running iOS 12.
Please fix/help asap as there is little point in using the system if the app on my phone no longer works. Thanks in advance .
Britdiver66
It is NOT an iPhone XS Max. Just the regular XS.
mathisje
Try Firefox browser.
pgelie
I am experiencing the same problem.  I have an iPhone XS running IOS 12.0.1 and I can not play the video recording from the arlo APP. Sounds like an APP issue, can someone from Net Gear find a patch?
richld01
Thank you for the suggestion, but that is not helpful. I do not want to use a web browser to view my recordings. My issue is on the mobile app on my phone, not on a tablet or computer.
Mccauley444
12.1.x fixes it
Britdiver66
Also the recent big app update did not fix the issue. It didn’t work on the old version of the app and still doesn’t when using the latest version.
pgelie
The latest OIS release is 12.0.1 to the best of my knowledge. Has anyone seen a 12.1 IOS release.
sjshoes
As requested in last post, I'm having playback issues on my original Arlo cameras, using my iPhone Xs Max running ios 12.0.1.   recordings have always worked prior to this new iphone. Getting terribly frustrated!!!
Mccauley444
12.1.x fixes it.   I installed beta 5 and it's working
Vortex123
Sinky
Having the same issue, cannot view any videos since getting the iphone XS, tried re-installing the app, turning everything off etc. guessing the app needs to update to work with the ios?
Zandian
Have to unsubscriibe to this thread. Just too many update emails with people reading the title and writing replies without actually digging into the thread a bit to find there is a fix.
rkaplan
support just gives the run around-the have no clue how long it will take to fix the iphone x bugs
MacMad
They are passing the buck and waiting for iOS 12.1 to come along.
