  • 1 Reply
  • 1629 Views
momac99
So, if the previous discussion was solved by replacing arlo pro base unit.  Is it safe to assume that arlo base units that have the same symptom after receiving a software/firmware update should be replaced? A lot of people are having this issue.
Anyone know if ARLO has capability of reversing a software/firmware update?
Has this issue been escalated to development?
I was planning to buy another base unit (fat one) for $79.99, but now i'm not sure after reading this previous discussion.
This discussion? https://community.arlo.com/t5/Arlo/Firmware-Update-fail/m-p/1704589#M68128
FWIW, adding on to multiple (and very old) threads isn't a good strategy - it's best to start your own.
I wouldn't reach that conclusion for your particular base yet.
What model base do you have?
What have you tried to resolve it?
