So, if the previous discussion was solved by replacing arlo pro base unit. Is it safe to assume that arlo base units that have the same symptom after receiving a software/firmware update should be replaced? A lot of people are having this issue.
Anyone know if ARLO has capability of reversing a software/firmware update?
Has this issue been escalated to development?
I was planning to buy another base unit (fat one) for $79.99, but now i'm not sure after reading this previous discussion.
This discussion? https://community.arlo.com/t5/Arlo/Firmware-Update-fail/m-p/1704589#M68128
FWIW, adding on to multiple (and very old) threads isn't a good strategy - it's best to start your own.
I wouldn't reach that conclusion for your particular base yet.
What model base do you have?
What have you tried to resolve it?
