Time stamp is wrong on videos
  • 14 Replies
  • 32325 Views
  • 3 Likes
  • 5 In Conversation
2ndrowe
I updated the arlo apt & now the time on every video is wrong, I receive a notification but the video is hours earlier.
2ndrowe,
I used UTC-06:00_ Central Time (US&Canada) and the correct time stamps resulted for that time zone. Is this the time zone you're using (it sounds like you're in Chicago)?
14 REPLIES 14
Check the time zone in settings...
if correct, the usu a reboot of the base fixes it ( power off then on)
2ndrowe
Hi,
Where in settings do I find the time zone?
In the settings for your base. A little poking around can go a long way.
2ndrowe
Time zone is correct, if I turn off base & turn back on do I then have to re-sync all cameras?
Thx
Nope. Power cycles have no effect on your setup. Only resets do.
2ndrowe
Hi,
Checked for correct time zone & powered off & on, time stamp is still 2 hours earlier than actual time.
2ndrowe
Hi,
Have been unable to solve my recording times. Each recording has a time stamp 2 hours earlier than actual time.
I have checked time zone in settings and it is correct.
I have also powered the base off & back on as suggested but neither option solved my issue.
Yesterday I updated the apt again which is what started the issue but still has wrong time.
Please help??
steve_t
Master Master
As a last resort workaround, could you change the timezone a couple of hours to get it to reflect the correct time? Obviously contact support first to see if there's a 'proper' solution
2ndrowe
Don’t know who’s time zone is 2 hours ahead of ours or I would have tried that.
Thx
Thx
https://www.timeanddate.com/time/map/
2ndrowe,
What time zone are you using that is behaving this way? Have you tried setting to a different time zone and then back to the original to see if you still get the wrong time stamp on your recordings?
2ndrowe
Chicago was the default which shows central time.
Yes I have tried setting to a California zone & back with no luck.
I finally gave up & contacted NetGear, they had me delete the apt & reload it but won’t know until this evening if it solved the issue or not.
Thx.
2ndrowe,
2ndrowe
Thank you, I was looking at time & date under general settings on iPhone & not in Arlo under devices.
Thx again😜
