2ndrowe,
I used UTC-06:00_ Central Time (US&Canada) and the correct time stamps resulted for that time zone. Is this the time zone you're using (it sounds like you're in Chicago)?
Check the time zone in settings...
if correct, the usu a reboot of the base fixes it ( power off then on)
Where in settings do I find the time zone?
In the settings for your base. A little poking around can go a long way.
Thx
Nope. Power cycles have no effect on your setup. Only resets do.
Checked for correct time zone & powered off & on, time stamp is still 2 hours earlier than actual time.
Have been unable to solve my recording times. Each recording has a time stamp 2 hours earlier than actual time.
I have checked time zone in settings and it is correct.
I have also powered the base off & back on as suggested but neither option solved my issue.
Yesterday I updated the apt again which is what started the issue but still has wrong time.
Please help??
As a last resort workaround, could you change the timezone a couple of hours to get it to reflect the correct time? Obviously contact support first to see if there's a 'proper' solution
Thx
@2ndrowe wrote:
Don’t know who’s time zone is 2 hours ahead of ours or I would have tried that.
Thx
2ndrowe,
What time zone are you using that is behaving this way? Have you tried setting to a different time zone and then back to the original to see if you still get the wrong time stamp on your recordings?
Yes I have tried setting to a California zone & back with no luck.
I finally gave up & contacted NetGear, they had me delete the apt & reload it but won’t know until this evening if it solved the issue or not.
Thx.
2ndrowe,
Thx again😜
