One of my 3 cameras has started showing a red tint. They are only 2 months old. I have installed 4 new batteries, that did not help. Rebooted the base station did not help. Resynced the camera did not help. Does anyone know how to fix this? Thanks for any help.
That ticket was long since entered and I never got a response. So your suggestion isn't really helpful unless you're familiar with the customer service failings noted all over these boards.
Hi,
Sorry to hear that. I did not get any response either.! But, the problem went away in a couple of weeks. I did not suggest anything 🙂
Good luck..!!!
I have the same issue.
On a positive note, Netgear support have been extremely responsive. I have had a very active diaslogue with a support person who has diagnised it as a hardware fault ... all on a Sunday afternoon.
Unfortunately, Netgear persevere with the view that I have to pay for the postage to return the faulty item to them. This is despite it being a known and common manufacuring flaw, and the camera being only six months old. There is an inference that they might pay for postage if I call them on their premium rate telephone line. Now...which is going to cist me more? Postage or being on hold at 40p per minute?! The answer is ... neither. Unless Netgear step up and see this from the customer's persepctuve I will be returning the entire package to Amazon and they can deal with it.
Well done Netgear on having a very responsive suport team. Unfortunately it is not matched by the fact that the customer has to be invonvenienced - not only from having a faulty product but also financially in getting it back to you.
Credit where its due ... less that 24 hours after reporting the issue, Netgear have agreed to replace at no cost to me.
Its still concerning that so many folk are reporting the same issues and I can only hope that I've had my one and only pink-tint-moment, but I have had a much better customer experince than others on this thread.
Hi all, I have 5 of these cameras and have had 3 with the pink screen. Two I returned to Maplin and they replaced ok. But the third I decided to strip it down and see what is going on. Here are my findings. The lens / camera has a electro mechanical filter that is driven by solinod, the purpose of this is the IR LEDs that come on at nights. At night this filter is not activated its only activated during the day.
I tested the solinod with my bench power supply set to 3 volts. Suprise suprise it worked fine. Makes that clicking noise that it should do. On feather investigation I discovered that the circuit for switching the solinod was giving 0 volts this means that the problem is at componant level and there's not a lot you can do except send it back.
On an interesting note if you want to see it work, place a magnet around by the camera tripod insert at the bottom and you can see the filter working.
Hmmm. I wonder if that could be a useful troubleshooting step. Can you describe in detail how you did that?
Installed new Arlo camera and had the same problem with the red tint. Turned the camera off and back on - no luck. Tried tapping camera on the sides - no luck. Tried a different approach, opened the battery lid and power down the camera. With the camera sitting on the face (lens) power up the camera and waited for the camera to activate - click live feed to get the night vision working. Slowly raise the camera off the bench until I heard the click, back to normal operation ( red tint fixed).
This did the trick for me as well. Thanks
Back to Arlo. We had our batteries start to last three days, then the cameras dropped off all the time after working great for several months. We had Arlo log in remotely and could not fix the issue then they offered to replace ONE camera and only after I filed a complaint with the Pa State Attorney General Office Of Consumer Complaints did they replace the entire system (they fought us even though it was under warranty). Now, we've had the same pink tiny everyone is complaining about and we're read these posts and did everything recommended. We used to highly recommend Arlo but no more. We're ready to bite the bullet and toss this system and buy a competitor's system.
One of my cameras has had a red tint for a while. I just gave it a tapping on its backside onto a few cloths on the work top. It worked (for now) back in full colour.
I had the same red tint problem as many people here, and I have come up with the CORRECT solution!
Its not a defective unit, you do not need to turn it off, reset it, or anything else.
The cause of this is because of the magnet on other units, when they are put close to the lense of another unit, they knock the IR filter out of alignment. Its super easy to fix, simply grab another camera, place the back of that camera to the bottom of the lense on the "red tint" camera. Voila! Fixed!
FYI, it's not the magnet. I Have 3 year old cameras that don't do this.
I agree, it is not the magnet. You got lucky with whatever you did fixing the problem. One of my cameras developed the infamous red tint while mounted on the wall. At the time it was no closer than 25 feet from another camera.
A while back I read somewhere that the tint was due to a red filter out of alignment. He stated that you had to send it back to the factory to be fixed. So I called the 800 number. After 10 minutes of going around in circles pushing keys I reached a young girl, whom I assume is just lovely, that I could barely hear let alone understand. The Philippines. It was obvious she was working from one of those association scripts as if I gave her a response that wasn't on her workbook, she hardly knew what to say. I have a camera that is less than 3 weeks old, it developed the red Tint. Like no one has ever brought this problem before. I won't list what she wanted me to try, then do with the camera BEFORE she would let me send it back. Three weeks old, it broke, replace it. If I did what she wanted, it would have cost too much in postage and time before I got it fixed. I then hit her with an H bomb. I told her just forget it. Give me the address and I will send it in and pay for the repairs. I just want a working camera. She had to talk to her supervisor. Neither of them knew what to tell me. If I followed the their original instructions they would see what they could do. I threw in the towel. I wish I had never seen this not made in USA company.
Part of your problem may be due to calling an 800 number. Netgear doesn't have one. Stop Googling for support when you can use the Contact Support link at the bottom here and again on the new page.
In reviewing daylight video of one camera in the front of the house, it appears "magenta" in color. Anyone have this occur?
Can you add a screenshot? It's a Pro 2 camera yeah? Is there direct sunstrike on the lens?
I am having the same issue. No solution provided by agent on the live chat. Simply troubleshooting camera which did not work. Any assistance greatly received.
You'll have to have an open case to get it replaced. Did the chat result in a case being opened? If not, contact again and get one going.
my HD Wireless Camera's Two are Great and Two show Pink color indoor and Red Out door.
Any suggestings before I Return?
sounds like the IR filter is stuck...
you can pull the battery and see if that resets it...if it happens a second time return or warranty is needed... Up to u
