One of my 3 cameras has started showing a red tint. They are only 2 months old. I have installed 4 new batteries, that did not help. Rebooted the base station did not help. Resynced the camera did not help. Does anyone know how to fix this? Thanks for any help.
Are you sure your insurance plan is threw Best Buy and not through Best Buy?
I've also got the red tint after just 2 weeks of ownership and Netgear wont replace it because it wasnt bought from an "approved seller" which is very poor on Netgears part as this is obvioulsy a widespread manufacturing fault! just cause i bought it from ebay doesnt mean this problem doesnt apply to me, it was brand new in a unopened box! not happy at all as it took 2 weeks for support to come back to me with this conclusion.
I did all the recommended treatments for the red tint. My red tint happens intermittantly and i am discovering it may be due to the weather. Last week was cold and i had the red tint. Today is mild and there is no red tint. Who knows?
On Mine I figured out that the camera that would show a red tint was facing into the sun in the morning. At first when I changed the batteries it fixed it but then that didn't work. That camera was replaced 2 times under warranty. After I got a 3rd camera I changed the way they were pointing and haven't had the issue since.
ETA: I have the Elite subscription so I think that helps when I call support.
While I have had problems with mine in the past Netgear has taken care of it every time. I do recommend them to people where it fits the application. Mine is a 3 camera system and my friend has the 5 camera system. He is not at all tech savvy and has never had a problem setting it up or working it.
Exactly the same crap happened to me. Bought brand new on ebay, netgear escalated it and concluded that they won't help me at all with the red tint
Most electronics companies do this unless you buy from an authorized dealer. I used to be big into car audio. I would pay the extra to get it from an authorized dealer. The companies have no idea how the items were handled by some discounter. They could even be stolen or knock off products if you don't buy from an authorized dealer. Also, like I posted before they gave me excellent support and replaced anything quickly.
Although Netgear's written warranty may only apply for authorized merchants, there is usually an implied warranty for fitness for use regardless of where you buy it from. If it can be proven that this is likely a design defect rather than a "handling" issue, then Netgear may be required to fix it whatever their warranty is. If the product is advertised to do something, then it needs to do it. I am not a lawyer, but I am concerned that we are talking about a product design defect here. It seems to me to be too common to be anything else.
After my camera fell out of tree, I noticed a red tint. Not sure if falling out of the tree was the cause. Rather surprised to see so many had run across the same problem. Followed one of the suggestions and opened the battery door and then closed it. Thankfully that did the trick.
After reviewing recorded videos I noticed mine turned pink after it fell (from tree mount). So a fall, in my case is the culprit. Opened battery compartment and closed it. That fixed it.
TINT it is not a tint it is the camera STUCK IN IR mode!!!
just tap it until you get the right colors. I did it and it worked!!! Keep tapping it or hit it with your fingers hard and it will come back!!!!
Let me know if it worked for you.
fred
tint, just tap the camera hard but don't break it. It is STUCK in IR mode and isn't coming out that is why if you look you will notice that your eyes look as though they are being seen in the dark with a Infa red camera. You'll get it back just keep taping and try it
let me know
fred
purplegunk wrote:I'm having the same problem now too! Grrr. Someone from Netgear please PM me!
let me know
fred
Debandtom wrote:
I also have a red tint that started yesterday
let me know
fred
tint it is the ir. It isn't changing back. just shake the hell out of it or tap it hard but not to hard and it will come back. You can tell it is the IR because when you look at it in the tint if you look at the eyes you see it looks like night vision, and that is what it is. Shake it back!!!!!!
fred
let me know if you got it to work
fred@nauticom.net
fred
fred@nauticom.net
Beach20 wrote:Not that I really think the requirement for the photos, battery swap and reboot is overly burdensome on its face value. It is just that I purchased these cameras to monitor a vacation home in Florida, so not so easy to jump thru those hoops from a 1000 miles away. I sent a link to my video feed, why do I need to Fly to Florida
fred
fred@nauticom.net
I have the same problem. Only displays red. Removed bateries, replaced with new ones no luck. Could you get it fixed? Or can it be replaced? My camera is 8 months old.
Hi there my camera has a red tint. I replaced batteries with new ones, replaced old one, no luck. Is there a way to fix this? My camera is 8 months old and never gets sun.
Looking forward to a reply.
