Random white lights while on night vision
I have something really weird happening when I leave my camera on in my lounge at night. The room is totally dark and once set up I go to another room to take a look at the view I get. This obviously triggers the infrared. A number of times I have observed random white lights of different sizes moving around the room often in an erratic manner. It is really odd. Nothing in the community appears to have any topics in this so I'm puzzled. When I've tested the camera I have then recorded 20-30 sec clips and these lights are as clear as anything. Spooky! Someone please tell me these have a scientific reason and aren't something else. When I've showed the clips to friends they also think they're weird and can't think of anything that would cause they random lights whizzing around my room in total darkness which can't be seen with the naked eye.
We have indoor and outdoor orbs they have rectangle shapes and go around the house and into th house and your out there telling us they are dust
The fact that objects with rectangular shapes passing thru walls ,doesn't necessarily mean ghosts but maybe energy of what once were living life forms . But don't say dust , we have observed these shapes for months the exact same shapes hanging out
I just noticed them too. https://arlo.netgear.com/hmsweb/users/library/share/link/B97A01A9DAE0D1C3_201708
Somebody's playing with a flashlight or pointer... 🙂
Hello
I recently installed security cameras at my main entrance and deck. The main entrance camera caught light objects as described in previous posts yesterday. This was similar to the light objects that were captured three weeks back in my backyard. They look like spider string. But I had a spider caught on camera too and I was able to see it as a spider. But these light objects caught were round hazy and moving randomly. It was as though someone was trying to play with flashlights but the camera did not capture any human in the vicinity. Some of my friends say its dust, some of them say its insects. It remains a mystery. It seems as though these cameras are capable of catching some particles that cannot be seen with the naked eye ... That's all I can deduce...But I must say its strange...
I think it was tiny bird down from a nest that was near a window close to the camera. What I was seeing did sail through the air like a feather of sorts caught in a current that knew where it was going because currents usually follow their own path. It is gone now.
https://www.youtube.com/watch?v=-4tI6iRSPWM
https://www.youtube.com/watch?v=ez2iJ7bYXVw
https://www.youtube.com/watch?v=Zf67yve-e0Q
https://www.youtube.com/watch?v=WTif2ImmlUg
https://www.youtube.com/watch?v=FrvoZUjMGYM
Dust. There's always air circulation even without fans.
Agree. That's dust
I too have very bizzare behaving "dust particles" captured on my footage. I had hoped to see the video you uploaded but it must have been removed. 😞
The best way to resolve this is to keep the lights off, then slap or beat your sofa in a fit of rage. Watch the entire community of angry orbs come out to voice their opionion 🙂
I have my status LED lights turned "off" in the App. I have night vision "off". At night one of the cameras looking outside through the glass turns on not the blue LED, but a white light turns on and reflects off the glass triggering false motion events. Any suggestions?
Its not actually white but appears so with night vision, which is in black and white. Even though you've turned off night vision, try toggling it again. If there's a Save opportunity, do so at each step. If that doesn't help, try opening and closing the battery door and power cycle the base. If it still doesn't help, remove the camera from Setting, My Devices and resync.
Good thoughts. Will try unplugging the camera as it is a wired Arlo Q. Thanks!
I am seeing these on the second floor and they are bigger than those seen here.
Yi home camera with night vision.
I have searched online and found some others that have seen similar but they are not this big. Comparing them to other objects in the room they are about the size of a tennis ball or maybe a bit larger. it sometimes comes from a different direction. It appears out of nowhere. This one seems to be comming out of the wall.
They appear large because they're close to the camera. A small object that's further away would be difficult to see due to the limited IR reflection as well as size.
Just confirmed the phenomena scientifically with a "shaking pillow" experiment: this is dust!
There was a birdnest outside the window and some down got through a crack somehow and that is what it was. Yeah dust is what it is.
