Random white lights while on night vision
I have something really weird happening when I leave my camera on in my lounge at night. The room is totally dark and once set up I go to another room to take a look at the view I get. This obviously triggers the infrared. A number of times I have observed random white lights of different sizes moving around the room often in an erratic manner. It is really odd. Nothing in the community appears to have any topics in this so I'm puzzled. When I've tested the camera I have then recorded 20-30 sec clips and these lights are as clear as anything. Spooky! Someone please tell me these have a scientific reason and aren't something else. When I've showed the clips to friends they also think they're weird and can't think of anything that would cause they random lights whizzing around my room in total darkness which can't be seen with the naked eye.
Much more than likely it's random dust or other floating material that has varying IR reflection qualities. Normal air currents in the room can be exacerbated by A/C (or heat, depending on the season) causing the material to float around in random paths rather than straight down. Having an open window not only adds air currents but also add additional material.
End result - random floating white spots. Happens outdoors, too.
Agree 100% ..... No ghosts, just dust !
I had thought they were dust particles but if you could see what they're like you would discount this immediately. First the variable speed of different lights and also some random movements which can't possibly be air currents in a room inside, at night with no wind at all. Seriously guys, this is more than weird. I will try and upload an example to YouTube and post it.
Ok .Tell me how dust can behave like this. These are random movements with some slowing down and changing direction . See this One example I uploaded http://youtu.be/2ni351MS1b4
Dust. That's all it is. Air currents aren't linear and lightweight objects like dust perform exactly as seen in the video. Guaranteed.
Any object that has a thermal mass from the day can give give off heat ( small as it may be ) at night and cause air currents.... there doesn't have to be any wind felt.... You've never seen dust particles dance in the sunlight beams before?
But if you what to think its ghosts, I don't want to spoil it for you. 🙂
You can generally tell when an insect goes by - the motion is different. Dust, etc. is a slower, more random motion.
i have had the same thing, however i have downloaded the video !
Just cant understand how this would be dust as it moves so quick ????
Nooooo, it's TINY ghosts ! 🙂
Hey, that is spirit...I'm catching crazy orbs on my camera on night vision. It's not dust. Trust me.
Give us a link to a video.
Have adder...this was yesterday morning when I was getting ready for work . I moved the camera for a different angle towards the end and the best orb is captured then. I have had so many once it actually disrupted the stream and wouldn't connect while my other cameras were fine. It's nuts! Let me know your thoughts. 😆
It's dust or other debris that is falling. It's weird, I know, but... I note that the camera is in B&W for low light level - I don't know for sure if the IR filter is in place but I'd kinda bet it is. If that's true, it may be that these orbs are just reflecting more IR than visible light, making them stand out more.
Well, let's agree to disagree.
Tiny spaceships landing? 🙂
I just discovered the same issue with my Arlo when it is in the night vision mode. I have checked to make sure the heat and air are turned off. Moved the camera to different points around the room. Taken it into other rooms. They are in all rooms except my office. I posted 12 videos on youtube of this. Could be dust but I've never seen dust behave this way?
How are you sure it's not dust/particles of some sort? Post screenshots or a link to the video.
your link didnt work for me but from what you describe i had similar with a competitor's cam in my shed. looked nifty. havent seen with my arlo yet though
