My notifications on iOS suddenly changed to 24 hour time. I have done nothing to cause this
The development team made some backend fixes and should now be fixed.
If you're still seeing the notifications showing in 24-hour time, please log out of the app and re-log back in. If the issue still occurs, try power cycling your Arlo devices to see if that helps.
Interesting. I haven't seen that on my iPhone 12 mini (currently running iOS 14.6).
Have other notifications (messages, etc) also changed to 24 hour time?
Did you go into Apple Settings (General -> Date & Time) and confirm that 24-Hour Time isn't set somehow?
For anyone who is experiencing their Arlo app showing as 24-hour time, could you please provide the following?
- Screenshot showing it in 24-hour time instead of 12-hour time
- What phone device you're seeing this on?
- What Android or iOS version and Arlo app version you are running on?
- What country are you from?
iPhone 12 on iOS 14.6
Arlo app 3.2 (2202)
@JessicaP I just noticed today. I have Iphone8 IOS 14.6 and no change as I just updated to that. Arlo App 3.2
It's just notifications. No big deal here as I have always used 24 hour at work but just to help others.
Hi! The time format just changed for me today on my iPhone 12 Pro Max notifications. I did an Apple software update overnight to iOS 14.6, so I'm guessing that is the issue. The 24-hour format is not selected in my iPhone's time settings, and I can't see any Arlo setting that provides a time format option, so I'm at a loss for how to change it back. Thanks for investigating!
@osr I had the 24 hour format today before updating to 14.6 a couple hours ago. So don't think that is it but yea good they are looking into it.
Not sure how/why this happened but the pop up notifications about motion are now showing in military time instead of what I will say is traditional time format. I've looked through my online account and through the app and don't see where choosing time format for notifications is an option. In the library it's showing regular time, it's just the pop ups that are doing this.
The development team is investigating these reports. We will provide an update as soon as we have more information to share with the community.
No changes have been made on the phone or Arlo of my doing.
Pleas see attached screenshot of the issue
Mine is doing this as well and I did not restore my phone, so I don't think that's the issue.
I am seeing it now. "Vehicle detected on Ultra at 20:30" for example. The system time itself remains in 12 hour time format (iOS says that notification was received "Yesterday, 8:30 pm).
Anybody else experienced this?
My Arlo was registering time using the 12 hour clock, now all of a sudden it's showing a 24 hour clock. I'm sure this change has something to do with an update, but does anyone know how to change it back to the 12 hour clock?
Just another reason to switch to Nest. Never, ever have any problems with them unlike Arlo. With Arlo, its always one thing or another.
Pixel 5, Android 11, US
Same problem here. 24hr format on notifications. Android 9, Samsung S8. All other notifications are in the correct time format. It's quite annoying. We don't use 24hr time here in the USA so give us the option to choose 12 or 24 or switch it back to 12 hr like it used to be.
What's the status on this?
