Excuse my ignorance but I`ve only visited the site a couple of times. How do I open a case? I don`t see a link from this page.
Tried the support page but the email/message link doesn`t work and apart from that, just go aroun in circles. Perhaps the Arlo software testing team will pick up on the bug some time. In the meantime, I`ll change all the other notification sounds on my phone so that only Arlo send the default tone so I can identify it. Cheers anyway.
Changing it in app settings worked, thanks.
Click on "ask a question" to start a new thread.
No reply or update from tech support yet.......
Second is make your default notification tone your arlo one then change the tone to your old default one on your other apps some apps don't allow a change so set those to no ringtone just notification bar.. Not perfect but a tempory workaround until hopefully its fixed.
When I change the Arlo alert notification sound from "default" to something different, it will still only play the default notification sound. It was working until the latest update of the app. While the app saves my preference to play a specific notification, when one is received it just plays my system default sound. Any ideas? This is annoying because I want a specific notification (different from the default) when my Arlo system detects motion and/or sound.
How I set custom notification sound:
- Settings -> Notification -> Notification Tone -> Media Storage -> (my custom sound)
What I've tried:
- Cleared the app cache
- Cleared all the app data
- Restarted the phone
About my app:
- version 2.6.3_23000 (11/20//18)
- Phone: Samsung S9 running Android 8.0.0
Something from the latest app update seems to have broken the notification settings.
I have a Samsung 8+ running 8.0.0. I found that setting notification tones through the Arlo app no longer works for me. What I did find from the last update was that now my phone can set the notification sounds through the Phone Settings>Apps>Notifications, where before there was no option to change tones. Using this (going through phone settings not the Arlo app) I got my selected tone to stick. It also fixed some no notification events I was having after the update. Not sure if this will work for others, but worked for me.
This is also the case for me. I have the Pixel 1 with Arlo Pro. It completley ignores the settings in the Arlo app and uses the system default settings for notifications. Including ignoring the Blink setting. I have tried every setting, deleted app/cache and even restarted phone. No dice. Please fix this soon because I am missing alerts!
Based on JoeCymru response - This fixed the problem for me.
- Open Android Settings (Not Arlo Settings)
- Open "Apps"
- Open "Arlo"
- Open "Notifications"
- Click on "Sound"
- Choose your custom sound
I think android may have updated how apps manage their notifications, and Arlo needs to update their App to accomodate this. It may require letting the Arlo App have access to "Change System Settings", which is pretty serious control for just enabling a change to the notificatoin sound. I'm just speculating here. But Arlo should fix this soon, as the "work around" is pretty clunky.
Hi everyone,
Our development team is currently investigating the issue where some users are unable to customize notification tones. We will provide an update as soon as we have more information to share with the community.
What version ANDROID do you have ? I have Ver 7.1.1 and It doesn't have a SOUND option within the ARLO app ?
8.0.0. This utility showed up only when the last Arlo app update was made (for Arlo). Previously the only way to control the sound tone was through the Arlo app, which now does not work for changing tones for me.
OK - Thats probably why I get different setting options. Different OS version.
I'm using 8.0.0, which has this option to set the notification sound via the Android System Settings.
Hello, I recently turned my base station off/on to reset the time. Now the notification has defaulted to default and I can't change it. I had it set to "knock", but for some reason I can't do it again. Can anyone help? Thanks
There is some help here
How do I set up notifications or alerts?
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
