I just changed my modem and now my base won't connect via ethernet cable. My power light is green, but my internet light is amber. I'm not sure what to do at this point. I did a factory reset and light is still amber. What can I try now?
The issue is NOT fixed for many people, including myself. For example, of my 6 server-connected devices (2 base stations, 3 Qs and 1 Q-Plus), only two are working right now.
Do you think this is just a matter of waiting for something on arlo side to get back up and running again?
been back for me a couple of hours. They're probably bringing things back server by server, country by country
I am completely conviced that for the 8 hours I have owned this equipment that I was robbed!
can not connect so are they down once again?
yes
Figures to much black friday I bet 😞
totally frustrating because I got impatient trying to figure out what the deal was. The support person would not level with me and say it was down. So I've ended up resetting my base station and removing the device from my account and trying to add it back with no luck.
At least I know I will be able to resolve my situation but now I will have to spend literally hours resyncing 7 cameras. Why hours???!! Because I have to break out a ladder and go to seven different position around the property. Removing each camera so I can resync within 1-3 feet of the router.
How much of pain!!!
“ Arlo just detected”
manfredz wrote:been back for me a couple of hours. They're probably bringing things back server by server, country by country
Did you have to do anything or did it eventually just come back up?
Geez I've been fooling with this thing for over an hour trying to get the cameras back up and running. I'm guessing the servers are down, maybe because of high demand from all the new customers that bought this system over the past couple days. I pretty much wiped everything and now I will have to start from scratch whenever they get back up and running. Really makes you question whether a cloud based solution is the way to go. Netgear should think about allowing local camera recording without the cloud becuase outages like this will leave a pretty bad impression.
Hi there!
Arlo HD Security camera (3 piece set).
Purchased new. Trying to set up. Connected th base to the router and to the power. Power light is green. Internet light is yellow.
Deffective product? Return to store?
Please let me know.
Regards!
Al
Glad to hear I'm not the only one!
It is possible Netgear/Arlo is having issues or may even be their AWS cloud provider. Earlier today I was receiving authentication errors when trying to connect from my mobile app to see my cameras. The same thing was happening on the website from my computer too. Even though the authentication issue seems to be resolved, my base station hasn't successfully connected since all of this started today. I have rebooted all my internet equipment with no change. Netgear/Arlo really needs a status page so their users aren't unnecessarily reseting their system and getting very frustrated.
Working yet? Just got it today and have been struggling all night. Now I see they have server issues...
is is there a site where we can see how their servers are doing?
I arrived home this afternoon not able to disarm the system from my phone. I unplugged my cameras and tried to reconnect. I was unable to reconnect. I removed all devices. But now I cannot add any devices.
