I just changed my modem and now my base won't connect via ethernet cable. My power light is green, but my internet light is amber. I'm not sure what to do at this point. I did a factory reset and light is still amber. What can I try now?
dougie41 wrote:Could this be related to the server connection issue others are experiencing?
I'm guessing it is. I was in the middle of setting up our last camera when it went down. Here's hoping it gets fixed fast!
Dougie, it could very well be related. For now make sure you have 2 green lights on the base. Wait a bit longer for the fix to propagate to everyone and then try and set up again.
Lost connection a few hours ago. Same problem says Arlo Device appears offline and base station won't connect to internet. Got error messages earlier about system. Cannot restart system from the app the feature is greyed out. Checked with my internet service (Comcast) is fine. Manually rebooted that router and the Arlo base station multiple times the middle light stays amber. Poor customer service to not post any updates if there is an outage. I am on a paid plan and not very happy about lack of communication from Netgear.
There is a fix?
it appears it is happening to more and more people.
What do you mean by "propagate"? If this is a server issue, shouldn't the fix apply universally anytime you try to reconnect the base station to the internet? How can this be a unit-by-unit rolled out fix?
I just bought the Arlo Pro today from Bestbuy and I cannot get it to connect to the internet. I get a solid Amber light regardless of any troubleshooting steps I have tried. I have read others are having issues today so should I wait a day or 2 to return and replace it or go ahead and return it for a different unit?
Meaning, at this point, with the amount of posts on multiple threads, all with the same exact issue....there is nothing to do but wait for Netgear to fix it.
Oh, it's probably to do with the network error that happened over the last few hours. Might just have to wait til the issue is resolved 😞
they need to hire more competent tech support
@dougie41 I would bet a $100 bill. I purchased mine today and got it set up before the system issues. If I were you, I would wait until all of this is resolved before investing any more time on it.
Read the posts
there is an issue right now, the very same issue is happening to a LOT of people.
Yes, but what stinks is how abysmal Arlo's customer care is -- there is no live support to be had, despite their claims of providing multiple channels. This isn't an entertainment product, it's a security system. Imagine if your alarm company just decided to ignore a major outage and not provide any information!!!
Agreed
I hope it's fixed soon too. This is not a good experience for a new customer. I tried to call Arlo but the USA number they post on this site doesn't work and chat support is offline too, which is extremely frustrating. I'll most likely retun the system tomorrow and be done with it. Can't believe I spent almost 1,000 USD on this system and there's no proper support structure in place. This is how compainies go out of business.
All of my bases and cameras are working. I had an issue earlier that was a server problem but that's been resolved, at least for me. It might be worth power cycling your bases to see if that resolves the issue.
Already been done, numerous times, still not working, just like all the others
Did you look at the literally hundreds of posts with the exact same issue?
Bought this and have been unable to get it to work. Most of the afternoon I got error messages when trying to establish an account. Now the base will not find the internet. I have rebooted the base with no luck. I connected my laptop to the USB cable provided and the laptop find the net without any problem.
Read to try resetting to the factory setting by pressing the reset button and the sync button until all three lights go to amber. Tried this and the lights never change.
Arlo server issues.. Not your unit. Few if not all are having same issues.
