I just changed my modem and now my base won't connect via ethernet cable. My power light is green, but my internet light is amber. I'm not sure what to do at this point. I did a factory reset and light is still amber. What can I try now?
I got it. I found that if you remove you base station and reinstall it everything came back. Ih ad the green lights but not for cameras they were amber. I have a ful up and running system again.
Had same issue after green light for intranet came on but amber for cameras. I removed the base stattion. Added it again, did the sync steps and it is all back.
I got mine back after removing base station devce and add it again. Sync cameras and all came back.
Remove base station and add device again. Synce cameras and it should all be back. I had amber lights also.
YEP...... i did the same and it is working this morning. YEAH.....
It would be great, if the next time you have problems on your end to let your customers know! I spent most of my evening trying to figure out what was wrong with my system. It wasnt until late last night that started coming accross threads stating you were having issues. It was great when I woke up this morning that it was magicly working. But it would of been better to know that when YOU knew there was isssue. Then I would not of wasted my time!!
I've still got the same problem, my base station is not connecting to the server. 8:30am in Arizona.
Thanks for the info. What a pain!
My base station did finally connect after removing and reinstalling it but I am also having to do the same with each camera one by one.
Glad that everything is working for you, now.
It was quite frustrating, yesterday afternoon, when I could not disarm my set-up. However, in short time, upon coming to these boards, I learned that many were experiencing the same issues.
Hopefully, Netgear has sorted this issue out and will be better prepared down the road.
I completely agree. I'm more frustrated with Netgear's failure to get information out to its customers right away than I am the outage itself. Not only did many of us spend time unnecessarily trying to troubleshoot on our end, we're talking about a security system that folks rely on, not a toy. I'm very disappointed in Netgear's handling of the situation.
alfrito wrote:It would be great, if the next time you have problems on your end to let your customers know! I spent most of my evening trying to figure out what was wrong with my system. It wasnt until late last night that started coming accross threads stating you were having issues. It was great when I woke up this morning that it was magicly working. But it would of been better to know that when YOU knew there was isssue. Then I would not of wasted my time!!
Arlo is back up and running for me in Christchurch NZ,at last 🙂
Just bought my Arlo Pro 4-camera system for Black Friday and was excited to set it up last night. However, came to this message board because I was having connection issues from the base to my router. None of the resets suggested by users here worked. I was about to box it up and return to Best Buy today, but when I woke up, I got the steady green light vs. the dreaded amber all last night. No idea what happened, but I'll take it. Set up all 4 cameras and they are now monitoring the house.
Will wait and see if the signal keeps. Model of base is listed as VMB4000
Yes. It improved in the morning. Like you said.
For more information please visit Some Arlo Base Station reporting as "Offline". We will continue to provide updates to that discussion as they become available. Please feel free to send me a private message if you need further assistance and we can continue troubleshooting with the assistance of our support team.
Best Regards,
____
Please click
My arlo is telling me it’s not connected to internet . Internet is fine I’ve checked everything what should I do
Using an HP laptop running Windows 10. Everything was working fine but for the last week unable to open the Arlo website. Using IE. Message says cannot open website due to outdated TFP on the website,. I can only assume there was a Windows 10 update as I have no trouble opening the site on an HP desktop running Windows 7 and using Chrome or on a new Chromebook.
You sure it's TFP? Dunno what that is - a Google search doesn't seem to pop up anything. I know of tftp (trivial file transfer protocol) but that's not used AFAIK. I use W10 with all updates with no problems. IE is a possible problem since it's really only for legacy applications - use Edge, Firefox or Chrome instead. Just make sure Flash is enabled since the latest updates to those disable it by default.
Good afternoon Arlo Community,
As you may have seen, we have posted an update that this issue should now be resolved. However, if you are still experiencing any issues related to the Base Station offline issue please feel free to reach out to me via private message and I'll be happy to continue troubleshooting this issue until it is resolved.
Again, we sincerely apologize for any inconvenience this issue has caused.
Best Regards,
Christine
____
Please click
