  • 7 Replies
  • 2971 Views
LydiaF
All event recording and notifications ceased at 9 AM yesterday morning.
The app is updated and no settings have changed on my end.
LydiaF
They just both randomly started working again so I guess someone fixed something on Arlo's end. Thanks for trying to help!
7 REPLIES 7
Can you still livestream the camera and doorbell?
If you have a subscription, can you save a manual recording while livestreaming?
Maybe also try changing the mode to disarmed, and then back to armed again.
LydiaF
Yes I've been able to livestream the whole time since this happened. My subscription is Arlo Smart, covering both
Ok. But can you save a manual recording while livestreaming?  And then see it in the library?
Also, did you try toggling the mode to disarmed, and then back to armed?
LydiaF
Yes and yes
Perhaps double-check the Armed mode (by going into the edit path), and make sure the rules for the camera+doorbell are still set to record and send notifications.
You could also try the motion detection test on the camera or doorbell.  https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
LydiaF
It failed the motion detection test. Should I restart it?
LydiaF
  • 7 Replies
  • 2972 Views
