Re: sporadic no Arlo smart notifications or recordings in library starting December 26 - case #4135
Highlighted
I'd like to update that since yesterday motion recording on my Three ultra and two pro2 cameras works just amazing! Since i own cameras now Motion field of view is just perfect!
Arlo please don't change anything Of this what u did and please make backups before you send out firmware updates to everyone 😄 !
PS haven't tested local sd card motion and recordings
Model: VMS5340 | Arlo Ultra 3 Camera Kit
Highlighted
Luminary
Luminary
I can report that my cameras still do not notify or save videos on the cloud that are on local storage. These occur randomly, and frequently, at least 4 times in the last 2 hours.
Probably silence from Arlo because it is not fixed.
Highlighted
Virtuoso
Virtuoso
Hi @Phoney49 , one important note I just found out which I wasn’t aware of is that the local recordings to the SD card record all the motion events from within the field of view of the camera.  While the recordings in our library/cloud only record motion activity within our defined activity zones (if you have activity zones set up on your cameras).
So, it is not fair comparison for us to compare the number of recordings on the SD card vs the number of recordings in our cloud library if you are using activity zones. . Not sure if you are aware of this too.
 Thank you!!!
Highlighted
Luminary
Luminary
Right, that is what activity zones are for. Unfortunately my system is failing to notify me about people, animals and vehicles that are moving through my activity zones. This is bad news for security cameras, and hopefully Arlo will tell us about a fix soon.
Highlighted
Prodigy
Prodigy
Quote. #4135
Hi @Phoney49 , one important note I just found out which I wasn’t aware of is that the local recordings to the SD card record all the motion events from within the field of view of the camera. Maybe this happens on your cameras but not on mine I am simply missing things in my activity Zone from the cloud
Highlighted
Prodigy
Prodigy
Add a new one, for me anyway. Last evening a driveway camera was triggered twice by a person with no notification or video in the cloud.  The strange thing is it shows on the SD card but only as a snapshot, no video.  Video shows as 0 sec.
Highlighted
I am still having missed recordings/notifications. I do not believe the issue has been resolved.
Highlighted
I havent got any recordings locally from the base to show up for nearly a week. Basically doesn't work at all now.
Highlighted
rgschmidt
rgschmidt Tutor
‎2020-01-05 09:35 AM
About 2-3 weeks ago for no reason my cameras became unreliable on sensing motion and recording. I can be sitting in my house when someone arrives or leaves and I get no detection from either camera sometimes. One is placed at the front door and the other is on the garage monitoring the driveway. I have an awesome WiFi setup and both cameras are receiving great signals. I have changed nothing in my settings and both cameras are set at maximum sensitivity. This has just happened for no reason at all and have become very unreliable. I noticed there was a recent update on the base unit. Does anyone know if that is the root of the problem. Also since this update my solar panel sometimes charges and sometimes doesn’t. I have the panel on only one unit. ( garage ) This needs to be fixed. Very high dollar useless system right now.
Model: VMS5240 | Arlo Ultra 2 Camera Kit
Highlighted
Noticing that still missing videos in library
Highlighted
I'm sorry I didn't check this forum before now as I contacted support on the 31st Dec (who got me to reset my base station and it made no difference) with the same issue and they arranged a RMA of the base unit.  Seems like the RMA will be a waste of time.
Highlighted
This is still a problem. Alexa will say "motion detected on the driveway" but I get no notifications are video recording. This a sporadic and intermittent problem. Pretty scary for my wife who works from home.
Highlighted
After a couple of good days something weird happened today. One of my three cameras went completely silent for seven hours, no notifications no recordings (even on the SD card). My other two cameras were working fine. After I noticed it I turned it off for a little while and after turning it on it is now working fine again.
Has anyone had this happening to them before?
Highlighted
Prodigy
Prodigy
Make no mistake this not been fixed. This morning pulled my car out of the driveway . Motion detected on sd card. No motion detected from cloud.
Highlighted
Yep, same for me. The preview in the app even shows my car in it with a local recording, nothing in the cloud and no Vehicle alert. I even have to sit there for a while as my garage opens so it has ample time to detect it as a vehicle
Highlighted
I have not yet contacted arlo yet. Was trying to find and answer through the community. Sounds mostly like it’s an arlo issue and I’m screwed with an overpriced security system that they want you to pay for extra monthly features that don’t even work. They need to fix there stuff and not charge anything xtra until they do or remove there expensive cameras from the market. I have 3 blink cameras that work flawlessly. I thought that I was making a huge upgrade to arlo instead a made a huge downgrade. There system is a discrace and we should all be compensated in some way for this. I’m so tired of buying what I think is the best only to be disappointed.
Highlighted
I stumbled upon this post yesterday and have noticed this as well.  It seems to be a sporadic issue since my ultra by the back door saw me going out this morning and sanding my driveway, but it did not capture my son taking the dog out this morning.  Normally I would think he was just b.s.ing me but he was very adamant and this wasn't the first time. I also reviewed other videos from @ 5-6am and they only recorded 0-1 second.....makes me wonder how much i might have been missing
Highlighted
Prodigy
Prodigy
Just pulled out of my driveway no notifications nothing on the cloud. But the event is on my SD card only
Highlighted
Virtuoso
Virtuoso
Hi @Johnny290
What helped me to get to working again I believe was deleting my activity zones and adding them back.
thanks!
Highlighted
Virtuoso
Virtuoso
Hi @rferrara
please try deleting and re-programming your activity zones.  I believe that’s what fixed me!
Highlighted
Virtuoso
Virtuoso
Hi @Xian65
Please try deleting your activity zones and re-programming them.  I believe that is what helped me!
thanks,
Highlighted
Virtuoso
Virtuoso
hi @rgschmidt
thanks,
Highlighted
Virtuoso
Virtuoso
Hi @findonsa I myself have not had that issue but if you are still having issues with sporadic missing cloud/library recordings and missing smart notifications.
thanks,
Highlighted
Virtuoso
Virtuoso
Hi @Jankovichs
thanks,
Highlighted
Virtuoso
Virtuoso
Hi @Nathan-aus
Please try deleting your activity zones and re-programming them.  I believe that is what helped me!  I’ve been working about for about 5 days now.
thanks,
