What mode is in use? Does it have a rule for the camera? Have you tried creating a new custom mode to see if that works properly?
Read the FAQs here on various topics, including how to modify and create modes and rules. The rules are inside the modes. Since you're using the Armed mode, try increasing the motion sensitivity setting for the camera in the mode - be sure to save. It may also be the distance, speed and direction of the motion that is at issue. Remember that people detection is only out to ~25 feet with sensitivity turned all the way up.
Heatseeker519,
Check to make sure the second camera is participating in your Arlo Smart subscription. You can check this by navigating to Settings > Subscription > Manage cameras.
@Heatseeker519 wrote:
now my front one is sending notifications and recording every car that goes by and I have a zone set for just the porch and yard but was told it could be due to the road being with in 25 ft and there is nothing I can do
Of course activity zones are supposed to solve that problem.
It looks to me like you could adjust the camera a bit more downwards, and avoid capturing the road (or at least most of it). I also suggest shrinking your activity zone - creating some more margin. You likely are particularly interested in the porch, so you probably don't need to include up to the edge of the sidewalk.
You could also turn off notifications for vehicles (and maybe "all other motion").
One thing I've noticed is that even with activity zones, I will get notifications at night - generally caused by the lights on emergency vehicles or sometimes trucks. The lights illuminate the activity zone, and the system can treat that as motion.
Accessing Local Storage
