Arlo Ultra outdoor mount
What mount can I buy that will work outside & mount to concrete?
The normal outdoor mount will work (VMA1000, VMA1000B). The screw thread is standard, so third-party mounts will also work.
There is a recent post on mounting to brick here: https://community.arlo.com/t5/Arlo-Ultra/Mounting-Cameras-To-Brick/td-p/1763651
You might also be able to glue a mounting block to the wall (or use mounting tape to attach the block).
Accessing Local Storage
