One of my cameras is set up at the front gate of my property looking toward the road. Its a county road so probably only one car per every few minutes. The road is 60ft from my gate so i need to utilize the activity zone to capture only gate movement and movement on my land. I have tried different size zones down to about a 2ft by 2ft box 100ft away from the road. I have also adjusted the sensitivity down to 5%. With both of these settings its still going off with cars driving by.
I read on the Arlo website you have to either have a Smart Subscription or the camera must be wired to power for activity zones to work. Since this camera system is only 1mo old, I show to still have the free Smart 12mo Subscription. I meet one of the requriements for Activity Zones to work yet they dont.
I would hope so. I'm around 10 days in currently and am really happy with them and so was looking to expand my installation. Read some of the issues people are having (that I hadn't noticed in my set up) and thought I'd better run some testing to confirm before I dropped another several hundred on additional cameras for locations that I need the features working on battery for.
So for now, I'm holding fire on more Ultras or Pro 3's. The only addition I've gone for right now is the Video Doorbell as I've been looking for one for 2-3 years. Withe the Arlo one being wired it fits the bill perfectly for my needs.
Secondly my activity zones are not working. I have the free 1 year trial activated and all my cameras are directly plugged into A/C power. No issues with my Pro 2 activity zones which have no subscription and plugged into A/C power.
I will try to attach a photo of the base station error and my activity zone problem. However my photos aren’t attaching.....Shocking
How can a person get a hold of support? I have called 3 times. left my number for call back twice and sent two emails.
My activity zones aren't working correctly. All the cameras are set for activity zones and randomly turn off notifications except 1. Some don't register activity at all. one registers activity outside the zone. NONE record for the max 3 minutes. I have had people walk up to my door and are only recorded driving up to it. The bear was recorded on the side of the house but not in front.
Nothing but trouble with this system. I am thinking all the positive reviews I read before purchase were paid for.
Netgear has great products but their support division needs serious help.
Pretty sure it’s a bug Arlo need to fix.
Once you get somewhere report back.
I have waited a week and a half for a response. Something is making me think that the company may be going under.
You do not need AC power for ultra activity zones if you are using one of the smart plans. You can use AC power or subscribe to a smart plan for motion zones.
Hi @njfoses
Your experience may differ, but from my now 4 days of continuous testing all different permutations of settings this is not the case for me. I have a smart plan active on all of my cameras (it runs out in just over 11 months).
My testing confirms that Activity Zones only work when using power from the AC adaptor. Without the AC adaptor connected the warnings in the iOS and web app remain (saying AC power is required) and motion based recordings occur even when the only motion is well outside of the assigned activity zones.
Perhaps you have different hardware/firmware versions?
Recordings will still happen outside of the zones but you will not be notified about them if using zones with smart plans.
Unfortunately that isn't the case for me either. Just had another notification for motion outside the zone right now.
However, one thing that is interesting is that despite having "All motion" detection switched off (all others are switched on), the cloud library does correctly limit the recordings held there by detection type. BUT despite this I still get notified of all types of detected motion. In addition the local library has ALL clips stored regardless of detection type.
unfortunately I must report that one of my 2 Ultra cameras started reporting motion detection notification and recording within my shaded area of the camera where it’s not supposed to report anything.
everything was working fine for about 7-10 days since you last reported the engineers made a change to fix.
now I’m not only getting motion detection notification and recordings within the shaded area, the camera is also identifying the vehicles in that shaded area.
can you please escalate back to the engineers again? It was working perfect up until this morning and I did not change one thing.
before my activity zones worked perfect.
thank you Arlo employee’s as always!
Keep telling everyone you can. If anyone asks me about Arlo I tell then to steer clear.
Hopefully we all know by this point that activity zones are not working properly yet. But I do want to clarify how zones are supposed to work, because there seems to be some confusion on that in several posts on this thread.
-Local Activity Zones are a feature in many (but not all) Arlo cameras, - in particular the Arlo Ultra, Pro 3, Pro 3 Floodlight, Pro 2, Q, Q Plus, and Baby cameras. The Go, Pro, and Video Doorbell do not support Local Activity Zones. Local Activity Zones require AC power (not solar panels). That is because the pixel processing needed is done in the camera and takes significant power. They are automatically disabled if the camera is not connected to AC power. When Local Activity Zones are in use, video is only streamed when the motion is inside the zone. So there won't be recordings either on the USB drive/SD card or in the cloud when the motion is outside the zone. Local Activity Zones do not require a subscription.
-Cloud Activity Zones are a (paid/trial) subscription feature available for all Arlo cameras. Whenever motion is detected in the camera, the video is streamed to the cloud. The cloud then determines if the motion is inside the zone or not. If the motion is inside the zone, the recording is saved in the cloud and a notification is sent. If the motion is outside the zone, the recording is not saved in the cloud (and no notification is sent), but it is saved on the USB drive/SD card. Cloud activity zones do not improve (or hurt) battery life - the camera streams the same amount of video whether cloud activity zones are being used or not. Pixelated or otherwise corrupted video will mess up the cloud activity zone detection, and personally I think that is one aspect of the recent wave of issues reported with activity zones.
-If you have a camera that uses Local Activity Zones and is also on a paid subscription, then the system should automatically shift to Cloud Activity Zones when power is removed from the camera.
-Both Cloud and Local Zones use the same configuration settings. One consequence is that in many cases users don't understand the difference between them, and often don't know what kind of activity zones they are using.
-You should not see the triangle warning on AC power being disconnected if your camera is on a paid (or trial) subscription.
-You should not be getting notifications or cloud recordings for out-of-zone motion if your camera is on a paid (or trial) subscription.
Thanks for typing this up as I agree there is much confusion among users on how activity zones are actually supposed to work.
The only piece I would disagree with based on my experience is
Motion outside of my cloud activity zones always end up as recordings in my library, just no notifications.
I'm not disagreeing with your results. I am saying that this is not the way the system is intended to work.
Smart notifications don't affect recordings. But cloud activity zones are supposed to supress both cloud recordings and notifications.
I wish i actually had confidence in the Arlo team to sort out all the activity zone issues, but their track record shows otherwise.
(It started again today reporting and recording to library and even identifying them as vehicles even though I made sure my street was in the shaded dark area)
hi @StephenB
have you been experiencing anything like this with your Ultra cameras?
my 2 uLtra cameras are on AC power via the 25 foot Arlo outdoor power cords.
but today and yesterday during the day I’m receiving motion detection notifications and recordings into my library for vehicles driving down my street. But please note I set up my cameras so that the street is in the shaded dark area using the cameras positioning’ setting under ‘device utilities’.
please also note I pay the monthly subscription for smart elite for the 2 cameras as well.
it started happening a lot more the last 2 days.
@JamesC @ShayneS @JessicaP any thoughts would be appreciated?
AC powered Ultra Camera = Yes
Activity Zone enabled = Yes
Trial Cloud Subscription = Yes
Smart Notifications = People Yes
Smart Notifications = Vehicle Yes
Smart Notifications = Animals No
Smart Notifications = Other Motion No
Expected behavior:
A) Motion, Vehicles, People, Animals outside of the activity zone should not result in a video saved in the cloud library.
B) Vehicles and people detected within the activity zone should result in the video saved to the cloud library and a notification sent to my phone.
Actual Behavior:
A) Any Motion, Vehicles, Animals, and People detected outside the activity zone are not identified as people or vehicles, animals but saved as videos, in the cloud library, labeled “motion”
B) Vehicles and people detected in the activity zone results in a video saved in the cloud library and a notification is sent to my phone.
I personally like the actual behavior (A) for legal purposes in case a person or vehicle is loitering outside the activity zone. But also I think Arlo should provide an ON/OFF switch for (A) for those people that simply don’t want videos of anything occurring outside the activity zones to be saved.
Accessing Local Storage
