  • 7 Replies
  • 1586 Views
Re_zeekay
Cannot live stream in full screen mode on Android app. When selecting full screen mode, orientation flips momentarily, then cancels the stream and reverts back to standard orientation. This happens everytime without fail, I have never been able to view live stream feeds in full screen mode.
7 REPLIES 7
Dannybear
Just a thought, is the phone screen rotation locked to portrait mode?
Re_zeekay
Unfortunately not, recordings are viewable in full screen. When you press the full screen icon all it does is cancel the the live feed stream.
Dannybear
Might be worth contacting arlo support if you have warranty or subscription. Look in app settings to access support.
ShayneS
Which version of the arlo app are you using? When did this issue first occur?
Re_zeekay
Version 3.6.8_28460. Android 12.
This has been the case since day one. I've had the app probably around 6 Months.
Dannybear
Just for reference, previous report of similar issue.
https://community.arlo.com/t5/Arlo-Pro-2/Arlo-Android-App-Will-Not-Rotate-Fullscreen-Live-Feed/td-p/...
Could it be a bug with the android version?
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
  • 7 Replies
  • 1587 Views
