  • 7 Replies
  • 3547 Views
  • 3 Likes
  • 5 In Conversation
amritwadhwa01
No recordings despite subscription and Chat didn’t help. Virtual assistant always appears to have problem sending code to email. Worst experience
7 REPLIES 7
DannyBearAgain
Welcome to the arlo user forum.
Why are you unable to contact arlo customer support using a phone?
ShayneS
Hi @amritwadhwa01
Are you still experiencing an issue?
mdube72
You can't even log in issue on the Arlo Chat support App - If you choose Base station as the option, then there is NOTHING in the sub menus to choose so how are you supposed to log an issue to get help with ?  Arlo has gone 100% downhill.   You used to be able to speak to a human.
Do you have a subscription? I can chose my hub and get support but I have a sub which is now required.
amritwadhwa01
Yes. I do have subscription
amritwadhwa01
I plan to cancel my subscription and look for alternative
ShayneS
Hi @amritwadhwa01
I have escalated this for you and someone from Support will be reaching out to you as soon as possible.
