No recordings despite subscription and Chat didn’t help. Virtual assistant always appears to have problem sending code to email. Worst experience
Welcome to the arlo user forum.
Why are you unable to contact arlo customer support using a phone?
You can't even log in issue on the Arlo Chat support App - If you choose Base station as the option, then there is NOTHING in the sub menus to choose so how are you supposed to log an issue to get help with ? Arlo has gone 100% downhill. You used to be able to speak to a human.
Do you have a subscription? I can chose my hub and get support but I have a sub which is now required.
Yes. I do have subscription
I plan to cancel my subscription and look for alternative
I have escalated this for you and someone from Support will be reaching out to you as soon as possible.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
