Since the recent app update, I've been getting new notifications that I do not want to see and I haven't found where to turn them off. I run on a schedule (9pm - 11:59pm + 12:00am - 6am) so I am getting a notification for each camera when armed and when a schedule is activated. So I get 2 push notifications at 9pm (schedule activated and camera armed) for multiple cameras. Then at 11:59pm I get another set of notifications (schedule activated and camera disarmed), again at 12am, etc.
This is TOO MUCH NOISE and makes it difficult to actually see the real events I would like to monitor. I only want to see push notifications for motion detected like it was prior to the upgrade. I've disabled mode change event types in the feed settings but this didn't seem to change anything.
Best answers
Thanks of your patience, this feature should now be available in all regions. Please make sure you have the latest version of the Arlo app installed.
You can find more information here: https://community.arlo.com/t5/Announcements/New-Feature-Mute-Mode-Change-Notifications/m-p/2488482#M314
I wanted to provide an update. This feature is live in most regions. It's not yet available in certain European regions, where rollout is still pending. We'll update if any changes are made.
Thank you for your patience.
Hi all,
A quick update on the mode change notification feature, it's currently in progress, but is now live on iOS, with Android support in the works. On iOS, mode change notifications are enabled by default and can be toggled on or off at any time in your notification settings.
appreciate the suggestion but uselsnotifications will still be on your screen after you disable focus mode and be blended with relevant notifications
interesting, I'll try it out - thanks!
Could you please help setting up this Focus on an iPhone? I can’t find anything with the label Focus. Thanks so much.
Ok got it. You meant Focus function in iPhone. Will give it a try. Thanks
Did you manage? 🙂
Sorry, you were right, my bad I started testing it last night and didn’t see the notification when I woke up. My schedule just changed, and the notifications showed up once the Focus turned off… Well, hopefully it at least helps with the sound.
I started to make a setup in Focus but then I realized that when all messages to my phone are ignored by focus then what is the point of having Arlo on during the night. I understand this a good temporary workaround to avoid hearing the sounds but I rather wait for real fix by the Arlo team. In the meantime I lower the volume instead on my iPhone 😁
The proposal was to schedule focus to start one minute before the scheduled mode change, and end one minute afterwards. So normal operation most of the night.
Thanks for your reply. I totally misunderstood the short period Focus setup explanation. I missed the short period part 😁. Now it makes sense. I will give it a try and use it until Arlo comes with a solution.
As if shoving an half baked app which broke all existing schedules wasn't enough, we're still waiting on this notification "fix". And don't try to answer with the iOS focus mode Arlo. Disabling something you've put in there yourself should not take a few months for a modern development team.
Still broken !
8 notifications per day…
very poor
Hi all,
Hi Shane. Thanks for the update. Could you please specify where to find this toggle on/off feature in IOS. I have updated the latest version of Arlo on my iPhone 11 and iPad Air 11 but can’t find anything. Thanks to advise.
Press the profile icon in the upper left. Then Notifications.
Thanks for your reply. There is no notifications in my app. I have checked around but no such function to be found. Any suggestions? Thanks
it is in Swedish but should be easy to understand
What do you see when you press "meddelanden"? That is where I see "Notifications".
@Lightfoto wrote:
Ok, so definitely not there.
Are you running either the 6.38 or 6.39 version of the app?
Also, it might not be rolled out in Europe yet. I'm tagging @BrookeN and @ShayneS to follow up on that aspect.
What I understand you can only silent the message for max 24 hrs and then you have to do that again the next day. This was already there before the latest update.
I run 6.39
I am on 6.39 too and i don’t have the option (IOS) in belgium
The feature you don't have yet is sticky, so will last until you change it.
For each location I see (in order):
- Notifications (which is the pause function you have)
- Mode Change Notifications (which is the new feature that lets you turn those notifications on/off)
- Critial Alerts (only available if you have Arlo Emergency Response as part of your subscription)
Ok hopefully they release it for Europe soon. Thanks for your help.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
