  • 35 Replies
  • 4163 Views
  • 23 Likes
  • 14 In Conversation
tmb-19
Since the recent app update, I've been getting new notifications that I do not want to see and I haven't found where to turn them off. I run on a schedule (9pm - 11:59pm + 12:00am - 6am) so I am getting a notification for each camera when armed and when a schedule is activated.  So I get 2 push notifications at 9pm (schedule activated and camera armed) for multiple cameras. Then at 11:59pm I get another set of notifications (schedule activated and camera disarmed), again at 12am, etc.
This is TOO MUCH NOISE and makes it difficult to actually see the real events I would like to monitor. I only want to see push notifications for motion detected like it was prior to the upgrade. I've disabled mode change event types in the feed settings but this didn't seem to change anything.
Best answers
  • Sithgear
    You can set up Focus mode to completely hide them. it's working for me.
  • ShayneS
    Hi @r3awak3n
    We do have some enhancements planned that should help with these symptoms. I will be sure to provide more information and updates here when possible.
  • ShayneS
    Hi all,
    Following up from last week, the team is still working on some enhancements. I’ll provide updates here as more information comes in.
35 REPLIES 35
malber
appreciate the suggestion but uselsnotifications will still be on your screen after you disable focus mode and be blended with relevant notifications
Sithgear
malber
interesting, I'll try it out - thanks!
Lightfoto
Could you please help setting up this Focus on an iPhone? I can’t find anything with the label Focus. Thanks so much.
Lightfoto
Ok got it. You meant Focus function in iPhone. Will give it a try. Thanks
Sithgear
Did you manage? 🙂
Sithgear
Sorry, you were right, my bad I started testing it last night and didn’t see the notification when I woke up. My schedule just changed, and the notifications showed up once the Focus turned off… Well, hopefully it at least helps with the sound.
Lightfoto
I started to make a setup in Focus but then I realized that when all messages to my phone are ignored by focus then what is the point of having Arlo on during the night. I understand this a good temporary workaround to avoid hearing the sounds but I rather wait for real fix by the Arlo team. In the meantime I lower the volume instead on my iPhone 😁
The proposal was to schedule focus to start one minute before the scheduled mode change, and end one minute afterwards. So normal operation most of the night.
Lightfoto
Thanks for your reply. I totally misunderstood the short period Focus setup explanation. I missed the short period part 😁. Now it makes sense. I will give it a try and use it until Arlo comes with a solution.
justinjanson
As if shoving an half baked app which broke all existing schedules wasn't enough, we're still waiting on this notification "fix". And don't try to answer with the iOS focus mode Arlo. Disabling something you've put in there yourself should not take a few months for a modern development team.
