Arlo Q not recording according to rules and not sending notification
  • 6 Replies
  • 4621 Views
Blue-dog
My Arlo Q doesn't record/send notifications when detecting audio or motion when armed.  It does record all the time so I can see in the history when it detects audio or motion.
First step is to remove from Settings, My Devices and resync.
6 REPLIES 6
Have you checked to verify that your mode or schedule is properly selected and accurate?
Blue-dog
Yes, even when manually set to ‘armed’, there are no recordings or notifications. The timeline does show there is activity though.
Blue-dog
I'll try it and get back with you - thanks
Blue-dog
Yes, removing it and re-syncing it fixed the problem - thank you!
Blue-dog
Problem reoccurred after adding CVR back to camera.  Deleting CVR corrects the problem which works for me but maybe not for other users.
