Arlo app only plays latest selected video no matter what video I select from my library. For example, if I select a video from earlier in the day, it plays the latest one. It was working fine until I updated to latest version of the app. iPhone app ver 2.7.1.
Arlo app on iPhone - I have 3 cameras. It will only play 1 video. The still shots show 3 cameras correctly, but when I hit play on cameras 2 and 3, camera 1 keeps playing. Works fine on PC. Restarted phone and base station. Same thing..
I was able to view the library on my Android tablet but not on my Mac. I opened a private window in Safari on my Mac and logged in - everything in the library was visible! Maybe my problem was different from others... I did unplug the Arlo base station and plugged it back in again but it didn't seem to make a difference. Maybe it was a combination of both?
this problem has been posted on this board a few times.
it is do to the bad app update on friday 2.7.1
you need to call support takes about 15 minutes and open a case#
they wont fix it unless we all open a case
they will tell you delete the app and reinstall it. that does not work !
besure to get a case#
1-408-638-3750 usa
Thank you, meizydavid, I called and got a case #. Spoke with Miguel. He did not tell me to reinstall. He said it is a "known problem", and there is no known work around at this time. They will call me back with any updates.
Well, that sucks. I like this system - is there no way to roll back to previous version, I wonder?
I didn’t know you could add other base stations?
How does that work ? What process would I go through ?
I get email alerts when there is motion. I can see them on my iphone and windows laptop.
The problem is with the app (only most recent video playing). Hopefully an app update is forthcoming.
1-408-638-3750 usa
FYI... If it helps to narrow down the problem, I am NOT experiencing this problem with Arlo App on my iPad Pro running same iOS 12.1.2, only having an issue with Arlo App on my iPhone. Hope this helps in troubleshooting your code...
Thick stone walls could be the issue, attenuating the signal. You can use as many bases as you need - it's the total number of cameras for your plan that is the limitation. If you add another base, position it so that some cameras will get a better signal. To do this, a WiFi or powerline extender can be used so the base can plug into it. Some trial and error may be needed to get the best location for the strongest signal to the cameras. Remove those cameras from the first base and sync to the second one. You may also want to reposition the first base so the remaining cameras get the best reception.
1-408-638-3750 usa
Same as everyone else. Playback from library selection fine on Android but plays only last video recorded on IOS 12.1.3.
Unistalled and resinstalled multi-times before reading that it was a known bug.
Waiting for fix.
Tried calling support mutli-times, always a bz signal.
All of a sudden, I can no longer watch videos other than the last one laoded up oby my camera, unless I delete it. Then I have to delete each video as I go in order to see the next one in line. I used to be able to look at any video in any order and did not have to delete one in order to see the next one in line. Any suggestions?
1-408-638-3750 usa
1-408-638-3750 usa
i dont think so as there are hundreds of users with same issue
1-408-638-3750 usa
I have the same problem where i have to erase videos to view the next one. What does getting a 'case number' do to solve this problem?
