Arlo app only plays latest selected video no matter what video I select from my library. For example, if I select a video from earlier in the day, it plays the latest one. It was working fine until I updated to latest version of the app. iPhone app ver 2.7.1.
Hi everyone,
As some of you may be aware, a new update is available for the Arlo iOS app. Make sure to install the latest version, which is version 2.7.2. We appreciate your patience regarding this. 🙂
Latest IOS update (iphone)
open app click on LIbrary, click on a previos recording, and only the latest recording will play...
will not play older recordings, just the last one made,,
I have 2 ARLO PRO 2 systems, and both are the same problem..
this is do to the latest ios update..
once again bad quality assurance
Same problem...
I have 2, ARLO PRO 2 systems with 15 cameras each...
I have this exact same issue, it is do to the latest IOS update yesertday..
typical of their quality assurance.
I have people ask me all the time do you love your system, do you recomend it ?
iI cannot recomend it
The really strange thing that has happened the last couple of days is that 2 cameras in completely different areas of the house started to show the same one view! So one facing back door one facing front door, suddenly both are showing the front door! Then today when I click on a clip from an activation, it shows the same clip over, not relevant to the activation I have chosen . No matter what clip I chose it only shows this one clip. Has anyone had this happen before?? I’m concerned my system had been hacked...
Power cycle your base station
Arlo recently had an upgrade to their app on IOS. Now when i got to my library and click on a specific video, that video does not play. The app plays the latests video taken. How am i supposed to look back on videos if any video i click on takes me to the most recent one?
I am unable to reproduce this on either of my iOS devices, it's working as expected on my end. I'm using an iPhone 8, Arlo app version 2.7.1. Can you provide more information such as the device you are using, the iOS and Arlo app version? I'm assuming you are trying to access the videos through the library?
If you mean turn the Netgear router on and off again? I’ve done that almost daily 😊
I have this same issue after update iphone 6S
happened after app update 2 days ago
It will probably be fastest to remove all devices from Settings, My Devices and start fresh. While a PITA, it usually clears out weirdnesses.
And you didn't provide the requested information?
version 2.7.1 released 2 days ago !
you need to call support takes about 15 minutes and open a case#
they wont fix it unless we all open a case
=they will tell you delete the app and reinstall it. that does not work !
1-408-638-3750 usa
Hi - I upgraded my arlo app to 2.7.1 and its playing the same video when I click on the various/different videos in my library. Any idea why? I am not having this issue on my iPad which has the previous version of the app.
1-408-638-3750 usa
IOS 12.1.2 APP 2.7.1 IPHONE 6S
you will need to call support takes about 15 minutes and open a case#
they will tell you delete the app and reinstall it. that did not work !
1-408-638-3750 usa
IOS 12.1.2 Iphone 6S / app 2.7.1
1-408-638-3750 usa
IOS 12.1.2 iphobe 6s / app 2.7.1
1-408-638-3750 usa
@Boscastle wrote:
Hi Steve,
Not the router but your Arlo base station
Since Arlo updated yesterdate I am having a problem. When I go to library now and click on a video it only shows the latest video. Like if I have 5 videos listed today and want to view the oldest one it will only show the newest. So in order to actually view the video I want I would have to delete all other videos. I hope this makes sense. Have had our cameras over 2 years and this has never happened before.
I just posted this same problem! Will call them.
I just got off the phone with support. They said it is a known issue and their team is working to fix it. Give it a couple of days to be resolved she said.
Hi everyone,
Our development team is aware where some users are having playback problems in the library on Arlo iOS app 2.7.1 and is currently investigating the issue. We will provide updates once we hear more information. We appreciate your patience and understanding.
