- 2
Does the new pro version take care of the delay between when motion is detected and when the recording starts? Can you always be caching the video to avoid the delay? It made the product useless as a security device for cars driving by, or even bikes. The delay was significant enough that if it did catch the trigger, it was almost off screen already.
Mine's only a week old and, so far, I'm disappointed. The delay is unacceptable.
BrutaLezzysNome,
This could be due to camera placement. Consider posting a screenshot of the cameras field of view along with a description of the motion you are trying to capture so we can better understand your cameras conditions.
the delay is still there and makes the camera useless for security, on top of risking loosing the device if thief knows about the delay...
I got mine last night and set it up pointing at about 25ft sidewalk, and the triggered recording started after the people walking out of the frame, on all occasions.
Love everything else about it but will have to return it and go for wired cameras.
Amvan,
The issue you are describing could be due to poor camera positioning, or the motion you are trying to capture is beyond the cameras range. Consider posting a screenshot from the cameras point of view so we can offer suggestions on placement.
- 2
