Cannot log in, https://arlo.netgear.com/#/login on my iMac just loads a blank page. FRUSTRATING !
I think they were able to find the issue and are now working on a fix for those of you that are still not able to log in, hopefully it won't be long before everyone is back online.
Thank you Dawn for your help. Hopefully what they found can help them fix it for everyone!
Yes, thanks to @KathyTW, we have identified the root cause and engineering is working on a resolution for all. It should be resolved shortly. I'll post an update once they've completed the fix. Thanks again Kathy!
The engineering team has implemented the fix, please try to log in again and let me know if you are able to successfully login. Thank you all for your patience!
Not fixed yet, i am in same boat - Works from Grantee but not Grantor (My wife's ID works but not mine)
I logged Priority 1 case with Netgear yesterday after 40mins call wait and 1 hour 40mins with Customer Support Rep.
Still no luck
I am available, please provide contact details and will call
Finally!!!! - I can login
Can somebody post Public facing RCA (Root cause analysis) for future reference
I can log in now....
Vancouver BC. iPhone X and iPad 9.7. Able to login again. Live feeds visible again. Have not tested other functions.
Everything seems working now
Need to know what happened? as it was directly impacting our Main Login ID which could be very well security issue
Netgear, Please provide details on issue/resolutions and prevention put in place for future
Did it go down again briefly at about 7 PM PDT last night? Or just me?
I had an issue last night also where I could not view my cameras. It didn't last long like this login issue, but I still very often will click "Live" to view a camera and it either 1) Takes several attempts to get the camera to stream, or 2) it plays sound but no live video feed.
Now on top of everything, out of the clear blue my Arlo android app crashed. I couldn't get it to disengage viewing a camera live. I couldn't log out.
Finally, I uninstalled the app and reinstalled. Then, it wouldn't let me login. It refused my valid password which worked fine on the PC app.
I had to change me password just to login normally.
I'm starting to worry that their IPO really means IN OUR POCKETS ONLY SUCKERS.
@Aec wrote:
Try powering off your phone, then powering it back on. That usually clears the caches enough to make the problem you’re having disappear.
Unfortunately, it did not. After two full reboots, the app remained locked into viewing a single camera and would not release.
Even after logging in via my PC web browser which forced the phone app to logout, when I logged back in, it was still locked onto viewing the camera and would not release.
Only uninstalling the app released it and then upon reinstalling the app, I couldn't login. I had to contact tech support who had me change my password which allowed me to log back in and from there things were reasonably back to normal.
Except of course, for BUFFERING....BUFFERING.....BUFFERING....BUFFERING.....
AND we're down AGAIN. "The authentication service is currently down"
yep another login outaage with the login. according to all the converters the login issue should have been fixed by now
Yes, seems to have been resolved... For now.
Read the post in the Arlo Stories section about this outage.
Dave4,
What are you experiencing that is preventing you from logging in? Are you seeing an error message on the login screen?
